2 Replies Latest reply on Jul 3, 2009 7:23 AM by wkirklutz
    Using Dynamic Names for MovieClips
    wkirklutz Level 1
      I am trying to simplify things by using dynamic MovieClip names. I have three MovieClips on the stage.
      1) mcPage1
      2) mcPage2a
      3) mcPage2b
      But my code isn't working. I'm guessing the "this" part is what is messing it up. Thinking that the computer doesn't know which MC is "this". It traces fine outside the function, but inside the function it traces undefined.
      stop();
      // import tween classes
      import mx.transitions.Tween;
      import mx.transitions.easing.*;
      if (firsttime<>1) {
      _global.MiddleOfPage = (Stage.width/2);
      _global.OnPage = 1;
      _global.NextPage = _global.OnPage+1;
      firsttime = 1;
      _global.PageFlipSpeed = .5;
      // Following Flips Page Forward
      trace(this["mcPage"+_global.OnPage]);
      trace(this["mcPage"+_global.NextPage+"a"]);
      trace(this["mcPage"+_global.NextPage+"b"]);
      //trace(this["mcPage"+(_global.NextPage)+"b"])
      this["mcPage"+_global.OnPage].onRelease = function() {
      trace("Inside Function: "+this["mcPage"+_global.OnPage]);
      trace("Inside Function: "+this["mcPage"+_global.NextPage+"a"]);
      trace("Inside Function: "+this["mcPage"+_global.NextPage+"b"]);
      this["mcPage"+_global.NextPage+"b"]._alpha = 100;
      var Animation:Object;
      Animation = new Tween(this["mcPage"+_global.OnPage], "_xscale", Regular.easeInOut, 100, 0, _global.PageFlipSpeed, true);
      Animation = new Tween(mcClick, "_alpha", Regular.easeInOut, 100, 0, _global.PageFlipSpeed, true);
      Animation.onMotionFinished = function() {
      Animation = null;
      var Animation2:Object;
      Animation2 = new Tween(this["mcPage"+_global.NextPage+"a"], "_xscale", Regular.easeInOut, 0, 100, _global.PageFlipSpeed, true);
      Animation2 = new Tween(this["mcPage"+_global.NextPage+"a"], "_x", Regular.easeInOut, _global.MiddleOfPage, 0, _global.PageFlipSpeed, true);
      Animation2.onMotionFinished = function() {
      Animation2 = null;
      nextFrame();
        • 1. Re: Using Dynamic Names for MovieClips
          only use the _global prefix when assigning a value to a variable that you want to make global, not when retrieving that value.
          otherwise:
          should work IF mPage1 etc is defined on the current timeline/scope.
          • 2. Re: Using Dynamic Names for MovieClips
            wkirklutz Level 1
            Figured it out. I needed to put those values in Variables:
            stop();
            if (firsttime<>1) {
            _global.OnPage = 1;
            firsttime = 1;
            Page = this["mcPage"+_global.OnPage];
            PageA = this["mcPage"+_global.NextPage+"a"];
            PageB = this["mcPage"+_global.NextPage+"b"];
            Page.onRelease = function() {
            PageB._alpha = 100;
            Animation = new Tween(Page, "_xscale", Regular.easeInOut, 100, 0, _global.PageFlipSpeed, true);
            Animation = null;
            Animation2 = new Tween(PageA, "_xscale", Regular.easeInOut, 0, 100, _global.PageFlipSpeed, true);
            Animation2 = new Tween(PageA, "_x", Regular.easeInOut, _global.MiddleOfPage, 0, _global.PageFlipSpeed, true);
            Animation2 = null;
            nextFrame();
