2 Replies Latest reply on Jul 4, 2009 1:49 PM by vertmonkee
    Native Menu
    vertmonkee Level 1
      I am trying to follow an example of a very simple menu from a book but it gives me an error message and I'm unsure why.
      Can anyone shed some light on it please.
      My code is as follows
      <mx:WindowedApplication xmlns:mx="http://www.adobe.com/2006/mxml"
          layout="absolute">
          <mx:Script>
              <![CDATA[
                  //Create the root menu
                  public var exampleMenu:NativeMenu = new NativeMenu();
                  //Create a sub item for the root menu
                  public var item:NativeMenuItem = new NativeMenuItem("Example item");
                  //Add the sub item to the root menu
                  exampleMenu.addItem(item);
          </mx:Script>
          <mx:Label id="welcomeMessage" text="Welcome to my desktop app" />
      </mx:WindowedApplication>
      I then tried adding in import statements, although these did get added even when I used the autocomplete from the code hinting
          layout="absolute">
          <mx:Script>
              <![CDATA[
                  import flash.display.NativeMenu;
                  import flash.display.NativeMenuItem;
          </mx:Script>
      The error message I get is at the exampleMenu.addItem(item) line and is as follows
      Multiple markers at this line
        - 1120: Access of undefined property item
        - 1120: Access of undefined property exampleMenu
      Any help is greatly appreciated.
      Thanks for reading
        • 1. Re: Native Menu
          leybniz Level 4
          your trouble is due to that line:
          as you can see it's not obvious for the compiler when exactly this line should be executed??
          to avoid error you'd better put your "real code"(not variables declarations) inside some function like this:
          private function onInit():void {
          and link this function to be invoked on application initialization like this:
          <mx:WindowedApplication initialize="onInit()" ... />
          If you feel this message answers your question or helps, please mark it respectively
          • 2. Re: Native Menu
            vertmonkee Level 1
            Excellent, thanks for your help.
