2 Replies Latest reply on Jul 5, 2009 8:51 AM by napervideo
    Old Premier Pro user, new to HD
    napervideo
      Hello:
      Got a new Canon HV-30 and couldn't resist recording something in HD.  I got it because the HDV format seems to at least be some sort of a "standard" among the tons of codecs popping up for "consumer" HD.  Anyway, I still use Premier Pro 2.0 because I have no problems with it. Don't see any reason to upgrade yet, at least until Wiindows 7 gets stabilized. Anyway, I have no problems importing HFD from the Canon HV30 into an HD project in Premier Pro 2.0. Surprised that the file is an .mpg because I thought I'd be editing in native HDV format. Which I realize isn't "true" HD (1440 x 1080 or something like that).  Unless of course "native" HDV actually IS an mpg codec which it very well might be for all I know. So the questions are:
      Is HDV really an MPG format and should Premier be turning it into an MPG before editing?
      If so, does this mean when I output the project, the file will get re-compressed again, and how bad does that re-compression screw up the HD video?
      What do you actually DO with this HDV once you have it edited?  I imagine I can output it back to MiniDV and tell the HV30 to record it in HD, although I haven't tried that yet.  And then you can plug the camcorder into the Hi-Def TV set via HDMI and watch it that way.
      I know Blu-Ray recorders are available for installation into my system, but haven't decided to do that just yet, although its my understanding that Premier Pro 2.0 will in fact output to Blu-Ray (??? yes/no??) If so, then that's probably the  best way to go I would think...
      But I have also been told that you can actually write some HD onto a regular DVD-R if you keep the project down to about 10 minutes. If so, how do you tell Premier to do that, and then how would you play it back?  Would a regular old DVD player recognize and play back the 10 minute clip in HD?  My gut tells me "no" but others are telling me "yes."
      If anybody can shed a little light on these questions, I'd appreciate it!
        • 1. Re: Old Premier Pro user, new to HD
          Yes HDV is mpeg straight from tape.
          Yes is gets recompressed same as DV.
          Yes write it back to tape and play it on a hd-tv or make it into BluRay (BR).
          I do not think Pro 2.0 does BR, no quite sure. Can't remember.
          Yes you can put hdv on a BR but you need a program like Encore CS3 or higher to make a BR-image. This image is burned on a regular DVD with e.g. Nero. About 20 minutes will fit on a dvd. Then you will need a BR-player to play this dvd.
          • 2. Re: Old Premier Pro user, new to HD
            napervideo Level 1
            Thank you!
            Dave
