2 Replies Latest reply on Jul 5, 2009 2:39 AM by essa tkinen
    return data from spark list itemrenderer
    essa tkinen Level 1
      Does anybody no how to return data from the itemrender for a spark list. say i had a checkbx in my itemrenderer how can I get that info back to my main component if its selected or not. I looked at datagrid and itemeditor but I really rather use a spark list. Thanks
        • 1. Re: return data from spark list itemrenderer
          _Natasha_ Level 4
          itemRenderer should be used only as a RENDERER. All chenges should be done in data.
          So if it's a checkBox, you should add click eventListener and change property in data to see that it's selected or not.
          • 2. Re: return data from spark list itemrenderer
            essa tkinen Level 1
            thanks I also found another way to doing it. A click handler on my list when that fires I can check if checkbx has been selected by doing event.target.document.mycheckBx.selected this will not work if using currentTarget cause it take the info from the itemRenderer. Now I understand the difference between currentTarget and target.
            not sure if this is a better way to access the data I think I might still just dispatch a event and do it your way.
            Its weird that mx:list has a editItemRenderer  and s:list does not
            thanks again TK
