2 Replies Latest reply on Jul 6, 2009 6:38 AM by froboz99
    Flex Builder 3: first directions in debugging / tracing applications
    froboz99
      Hi all,
      I'm sure this is a rather trivial question, but I've spent some time on it and still can't figure out how to move forward.
      I've created this very little ActionScript project, using Flex Builder 3 for linux.
      This is the code of the simple application I'm writing:
      -------------------------------8<------------------------------------------
      package {
          import flash.display.Sprite;
          public class HelloAction extends Sprite
              public function HelloAction()
                  trace("Hello world!!");
      When I click on the Run button, the flashplayer is executed on the compiled swf file, and I get the application run on an
      empty stage, which is afterall what I expect, still I have no idea where the trace message should appear.
      Then I tried to click on the "Debug" button, I can see in the progress view something happening with my fine app, something like:
      Launching HelloAction:
      [BAR]
      Launching: Waiting for Flash Player to connect to debugger
      and the bar slowingly filling itself, then finally I got this message:
      |Failed to connect; session timed out.
      |Ensure that:
      |  1. You compiled your Flash application with debugging on.
      |  2. You are running the debugger version of Flash Player.
      Can someone provide some hint?
      What am I supposed to do in order to be able to simply see the trace messages?
      Regards.
        • 1. Re: Flex Builder 3: first directions in debugging / tracing applications
          *Prashant Shelke* Level 4
          trace will be available only for SWF compiled with -debug=true setting.
          Right-click on project -> Properties --> Flex compiler --> Additional compiler arguments --> add -debug=true.
          Clean project & try to debug u will see trace logs on colsole view in eclipse & also ensure you have installed Debug version of Flash player or no.
          • 2. Re: Flex Builder 3: first directions in debugging / tracing applications
            froboz99 Level 1
            Hi, and thanks for the reply.
            I did this:
            and compiled, apparently without problems.
            Then I got a flashplayer debug version from this url:
            http://www.adobe.com/support/flashplayer/downloads.html#fp9
            And I installed it in the path.
            Now I have:
            $ which flashplayer -a
            /opt/adobe/flash-player-dev-9/standalone/debugger/flashplayer
            $ /opt/adobe/flash-player-dev-9/standalone/debugger/flashplayer foo
            Error: Invalid SWF file name
            But then again when I try to click on the Run button I can see no application launched, and when I try the Debug button I get the
            same problem as  before, with the funky progress bar "Launching HelloAction" slightly progressing and then ending up with the usual timeout message:
            |Ensure that:
            Yes I also tried to clean the project.
            Any other suggestions? Is it possible that this "feature" is not supported in Linux?
            Regards.
