2 Replies Latest reply on Jul 6, 2009 10:26 AM by RockScript
    is it possible to write script that will show script folder files in tree view
    RockScript
        • 1. Re: is it possible to write script that will show script folder files in tree view
          Thomas B. Nielsen Level 3
          Yes :-)
          In your previous post someone suggested to find the file "SnpCreateTreeview.jsx", since it would do just the requested.
          The script can be found here, just accept the EULA and download the CS3 Bridge example scripts. (For some reason it's not in the CS4 samples as far as i can tell)
          Here is a version with small edits, it's up to you to point the script to the right "root" folder, as it is here, it goes from C: on PC:
          // ADOBE SYSTEMS INCORPORATED
          // Copyright 2007 Adobe Systems Incorporated
          // All Rights Reserved
          // NOTICE:  Adobe permits you to use, modify, and distribute this file in accordance with the
          // terms of the Adobe license agreement accompanying it.  If you have received this file from a
          // source other than Adobe, then your use, modification, or distribution of it requires the prior
          // written permission of Adobe.
          @fileoverview Shows how to use a tree-view list element, and how to capture events with
               either callback functions or script-registered event listeners.
          @class Shows how to use a tree-view list element, and how to capture events with
            <h4>Usage</h4>
             <ol>
             <li>Run the snippet in the ExtendScript Toolkit (see Readme.txt).
              <li>Expand and collapse the list elements
              <li>Inspect the JavaScript Console to see the captured events from the TreeView elements.
            </ol>
            <h4>Description</h4>
            <p>Creates two TreeView hierarchical list components. One is static, with a fixed set of item
            nodes that you can expand and collapse. The other is dynamic; item nodes are added and removed as
            as needed to show a view of the filesystem.
            <p>The list items in the TreeView use custom images to display folders and files.  When adding items to the
            TreeView list, the type 'item' is used for leaf elements and 'node' for container elements.
            <p>The dynamic TreeView captures events in two different ways. It uses callback functions to capture the
            node expand and collapse events and selection changes, and also registers an event listener to
            capture double-click events.<br />
            @constructor Constructor
          #targetengine "session"
          function SnpCreateTreeView()
               The context in which this snippet can run.
               @type String
              this.requiredContext = "\tNeed to be running in context of Bridge\n";
                The file-system location of this script
                @type File
              var scriptsFile = new File($.fileName);
                The file-system location of the PNG resource file used to represent folders
                @type File
              this.folderIcon = new File(scriptsFile.path + "/resources/Folder_16x16.png");
                The file-system location of the PNG resource file used to represent files
                @type File
              this.fileIcon = new File(scriptsFile.path + "/resources/Story_16x16.png");
                The root folder that will be used for the dynamic tree
                @type String
              this.rootFolder
              if(File.fs == "Windows")
                  this.rootFolder = "C:";
              else
                  this.rootFolder = "/";
          Functional part of this snippet. Creates the ScriptUI window and its components ,
          and defines the behavior.
          @return True if the snippet ran as expected, false otherwise
          @type boolean
          SnpCreateTreeView.prototype.run = function()
              $.writeln("About to run SnpCreateTreeView");
              // Create the window
              var win = new Window("palette", "SnpCreateTreeView", undefined, {resizeable: false});
              // Create the panel for the static TreeView
              var sPanel = win.add("panel", undefined, "Static TreeView Element");
              sPanel.alignment = ["fill", "fill"];
              sPanel.alignChildren = ["fill", "fill"]
              // Create the TreeView list
              var sTv = sPanel.add("treeview");
              sTv.preferredSize = [300, 200];
              // Add static items to the list, in a hierarchical structure.
              for(var i = 0;i < 10;i++)
                  sTv.add("node", "Item " + i);
                  for(var j = 0;j < 4;j++)
                      sTv.items[i].add("item", "Sub Item " + j);
              // Create the panel for the dynamic TreeView
              var dPanel = win.add("panel", undefined, "Dynamic TreeView Element");
              var dTv = dPanel.add("treeview", undefined);
              dTv.preferredSize = [400, 300];
              // Create the root node item
              var aNode = dTv.add("node", "/");
              // Associate it with an icon image
              //aNode.image = this.folderIcon;
              // Define an event handler for double clicks
              myOnDoubleClick = function(e)
                  if(e.detail ==  2)
                      $.writeln("Double Click");
              // Add the handler as an event listener to the TreeView element.
              dTv.addEventListener('click', myOnDoubleClick);
              // Keep a reference to this object
              var that = this;
              // Define an event handler for when a node is expanded
              dTv.onExpand  = function (item)
                  $.writeln(item.text + " is now expanded.");
                  var nextItem = item;
                  var path = "";
                  var goUp = true;
                  while(goUp)
                      path = "/" + nextItem.text + path;
                      nextItem = nextItem.parent;
                      if(nextItem instanceof TreeView)
                          goUp = false;
                  // Remove all the children of this item
                  item.removeAll();
                  var ref = new Folder(that.rootFolder + path);
                  if(ref instanceof Folder)
                      var children = ref.getFiles();
                      for(var i = 0;i < children.length;i++)
                          if(children[i] instanceof Folder)
                              item.add("node", children[i].displayName);
                              //item.items[i].image = that.folderIcon;
                          else
                              item.add("item", children[i].displayName);
                              //item.items[i].image = that.fileIcon;
              // Define an event handler for when a node is collapsed
              dTv.onCollapse = function (item)
                  $.writeln(item.text + " is now collapsed.");
              // Define an event handler for when the selection changes
              dTv.onChange = function()
                  $.writeln("Selection has changed");
              // Display the window
              win.show();
              $.writeln("Ran SnpCreateTreeView");
              return true;
          "main program": construct an anonymous instance and run it
            as long as we are not unit-testing this snippet.
          if(typeof(SnpCreateTreeView_unitTest ) == "undefined") {
              new SnpCreateTreeView().run();
