two problems about RoboHelp 8.
1, It is said that JavaHelp Help and Oracle Help can be the output format of RoboHelp project in the help of RoboHelp. But I can not find a way to generate JavaHelp or Oracle Help. Could you tell me does RoboHelp 8 support it?
2, Generate and publish output from the command prompt. I use the command as below:
"e:\test_RoboHelp\robotest\robotest.xpj -l WebHelp -o E:\test_RoboHelp\a"
"e:\test_RoboHelp\robotest\robotest.xpj" is a project which does exist. But Why the output folder is not "E:\test_RoboHelp\a" as I have set?
Addressing 1 only.
Is the problem that the list of output types does not include those outputs or that they do not work?
If the former, right click in the layout pod and add a new layout, you will be able to select those types.
If the latter, see the JavaHelp page on my site.
