4 Replies Latest reply on Jul 7, 2009 8:41 AM by UbbaWub
    Rendering from Premiere
    UbbaWub
      Forgive my apparent stupidity but inside of Premiere, I grab (Highlight) a series of video selections from the timeline and choose (right-click) to render in After Effects (CS4).  Then I discover that I needed to change something about one of the slices of video (sequence grabbed from the raw footage) and cannot go back to the original state that the video was in before I rendered in After Effects...or can I?  Does this make sense?  I try to undo everything in after effect and lose the video altogether in Premiere...I feel like a complete novice...
        • 1. Re: Rendering from Premiere
          Bl4ke360
          I don't really follow what you're saying, but do you have the original video accessible in premier? If so, re-edit what ever you needed, and then import that back into after effects. If not, export the video from after effects to a video file which you can open with Premier and start all over again.
          • 2. Re: Rendering from Premiere
            UbbaWub Level 1
            I have to restate part of that initial comment.  I'm actselecting some footage from the timeline in Premiere, then right-clicking to create a composition in After Effects, when all of this happens.  Does that make sense?
            • 3. Re: Rendering from Premiere
              I'm not sure what you are trying to say. The behavior of Replace with AE composition is exactly that - it creates an AE comp as a placeholder in the timeline, where the original clips only exist in the comp, but on the Premiere timeline the container is visible? You cannot edit this comp any further in Premiere. If you need this functionality, you will have to use conventional nesting, duplicate timelines and sub-clips to virtually duplicate your footage, if the original edits need to be retained.
              Mylenium
              • 4. Re: Rendering from Premiere
                UbbaWub Level 1
                Mylenium,
                So, how would I go about using conventional nesting to duplicate timelines and sub-clips and would there ever be a reason for doing so?  Maybe I need to rethink my workflow process?
