When I update just a few topics in my RH 7 HTML projects, like with simple typo corrections, do I have to regenerate the entire WebHelp and re-publish all files?
Hi there
You only have to do that if you want it to work.
Cheers... Rick
Helpful and Handy Links |
Republish only those files that have changed, and you should be fine. Note that this is probably more than just the topics you made the corrections in—the corrections probably affected the XML files that support the search function.
Ben
Hi Ben
LOL, doesn't the word "Publish" somewhat imply that?
Cheers... Rick
Not necessarily. Part of the original question was whether the entire set of WebHelp files had to be republished. Your answer implied that the entire set of files had to be republished after regenerating WebHelp, so I was clarifying that the bare minimum you need to republish is the files that changed.
LOL, okay sure
I was thinking in terms of using the Publish function built into RoboHelp. By default, until you change it, only changed content is republished.
Are you going to get in trouble with Darth Sidious? Using Flare and hanging out here in the RoboHelp place?
Cheers... Rick
Actually, I haven't embarked on my Dark Side training yet, but it will be any time now. Already I feel myself fading away from the RH forums like Yoda at 900 years old...
