4 Replies Latest reply on Jul 8, 2009 4:48 AM by leybniz
    How to expose to test automation dynamically generated third party component
    miroslawp
      We need to expose to test automation extended check box (which is not our component), that is dynamically generated and works together with tree.
      So, our application contains the  following code:
      import org.sepy.ui.CheckBoxExtended;
      checkBox = new CheckBoxExtended();
      Then all properties of check boxes are set dynamically.
      These check boxes are  used with the tree, to select  any of its nodes.
      When using test automation tool (we are evaluating RiaTest), automation tool agent sees the tree, but it does not see checkboxes, and therefore selection  of tree node cannot be automated.
      Is there any  way to make automation tool agent see this check box? There is a procedure for instrumenting custom components, but this is like third party component.
      Miroslaw
