2 Replies Latest reply on Jul 7, 2009 9:18 PM by Adobe-InDesign CS4
    [CS4-JS] - How to read the XML File / content value - reg.
    Adobe-InDesign CS4 Level 1
      Dear All
        I'm having one big doubt, regarding for reading the XML file Tag and Content to stored one variable....
      for example:
      test.xml
      <Roots>
      <title>XML Reading </title>
      <author_group>
      <author>
      <fname>Harihara</fname>
      <sname>Sudhan</sname>
      </author>
      <author>
      <fname>Adobe</fname>
      <sname>forums</sname>
      </author>
      <autor_group>
      <infos>
      <date><start_date>Today</start_date><end_date>Tomorrow</end_date>
      </date>
      </Roots>
      How to read [each and every element and its value] the above xml file through JavaScript.
      For example I need the Tag <start_date> and its value to stored in one variable like...
      Tag_name = start_date;
      Tag_value = Today
      So, How to read the XML File using JavaScript [XML DOM] and stored each and every Tag content values....
      Please any one can give me a solutions, then I will be appriciate....
      Thanks & Regards
      T.R.Harihara SudhaN
        • 1. Re: [CS4-JS] - How to read the XML File / content value - reg.
          Thomas B. Nielsen Level 3
          Hello,
          First of all, your XML is full of errors, please post proper info, i like to help, but not editing typos.
          Have a look in the Javascript Tools Guide CS3 under XML
          var roots = new XML("<Roots><title>XML Reading</title><author_group><author><fname>Harihara</fname><sname>Sudhan</sname></author ><author><fname>Adobe</fname><sname>forums</sname></author></author_group><infos><date><st art_date>Today</start_date><end_date>Tomorrow</end_date></date></infos></Roots>");
          var myEveryName = new Array();
          traverse(roots);
          alert(myEveryName);
          function traverse(tree) {
              myEveryName.push(tree.name()); // you get the contents by using .text() insted of .name()
              if(tree.elements().length() > 0) {
                  for(var i=0; i<tree.elements().length(); i++) {
                      traverse(tree.elements()[i]);
          • 2. Re: [CS4-JS] - How to read the XML File / content value - reg.
            Dear Thomas
               Many thanks for the responce...and I'm really sorry to say for I made a mistake in the xml...
            Please here my original xml file
            Preflight.xml
            <Profile_config>
            <Profile_name> Els_pitStop</Profile_name>
            <Rule_name>
            <!--       Blank Page Rule Set  -->
            <Blank_pages>
              <Ignore_master_page> true </Ignore_master_page>
              <Ignore_nonprinting_objects> true </Ignore_nonprinting_objects>
            </Blank_pages>
            <!--     End of the Blank Page Rule Set   -->
            </Profile_config>
            I used the abobe xml to read each and every elemet using for REGEX operation.
            I used regex operation to read & match each and every element and get the content.
            For Example:
            var Fpath = File("D:\\Preflight\\Preflight.xml");
              if (Fpath.exists)
               Fpath.open("r");
               var Cont= Fpath.read();
               //-------------------------------- Profile Name ---------------------------------------------//
               var Profile_name=/(<Profile_name>(.+?)<\/Profile_name>)/gi;
               if(Cont.match(Profile_name))
                var result = Profile_name.exec(Cont);
                var profileName = result[2]; //index 0, 1, gives full matching pattern
            //-------------------------------- Blank Pages  ---------------------------------------------//
                 var Ignore_master_page =/(<Ignore_master_page>(.+?)<\/Ignore_master_page>)/gi;
                 if(Cont.match(Ignore_master_page))
                  var result = Ignore_master_page.exec(Cont);
                  var ignore_master = result[2];
               var Ignore_nonprinting_objects =/(<Ignore_nonprinting_objects>(.+?)<\/Ignore_nonprinting_objects>)/gi;
                 if(Cont.match(Ignore_nonprinting_objects))
                  var result = Ignore_nonprinting_objects.exec(Cont);
                  var ignore_nonprinting = result[2];
            I used the above method is taken more than 10 min. Instead of the above method, please any one can help me to directly read the XML [XML DOM - used] to solve my problem.
            Because I tried your coding but its not working....
            Plaease kindly help me to solve the above XML -DOM reading problem through JAVA Script.
            Thanks & Regards
            T.R.Harihara SudhaN
