7 Replies Latest reply on Jul 8, 2009 3:00 PM by Jim_Simon
    Newbie File Size and Sync issues
    nin9999 Level 1
      Background:
      Premiere/AME newb
      MacBook Aluminum 2.4Ghz Core 2 Duo 4GB
      OSX 10.5.7
      Premiere 4.1, AME 4.1
      Source Files are screen recordings from iShowU app Quicktime, H.264, AAC 44.1Khz, 640X400, 2-10 frames per second (average size 1.5MB per 1:00 video)
      I am recording 'simple' training videos using a screen recording app called iShowU and then I need to do a few edits and combine video's in Premiere. These video's will be used in pdf's and online on our website.
      I setup a project in Premiere with settings:
      - Desktop editing Mode
      - Timebase 10 Frames per second
      - 640 X 400 frame size
      - Square Pixels
      - No Fields Progressive Scan
      - Display format Frames (only option)
      - Audio 44.1khz
      I make a few minor edits by cutting videos and ramping up the volume and then export a 5:00 video to AME with settings:
      - Quicktime
      - H.264
      - 100% Quality
      - 640 X 400
      - Frame Rate 10fps
      - Progressive Field Type
      - Square Pixels
      - Render at Max bit depth (tried this on and off)
      - Optimize Stills
      - Frame Reordering (tried this on and off)
      - Set bitrate to 1000 kbps
      - AAC 32k
      After export the audio is out of sync a second or two. I upgraded to the AME 4.1 which i thought was going to fix the sync issues but it didnt. If the syncing issue is caused by the settings im using i wouldnt be surprised.
      THe big issue is that my file sizes are really large (20+MB when I need 10MB or less). I did some edits before I reinstalled everything and before upgrading to AME 4.1 and the files were smaller then so I am sure I am doing something wrong now.
      Any suggestions on proper project or export settings to achieve good output for what I want to do would be much appreciated.
      Thanks very much in advance,
      Jason
