2 Replies Latest reply on Jul 7, 2009 11:27 AM by eapre
    Still need help with play and pause
    eapre
      Ok, I thought I had my problem figured out but as I looked more closely I found I didn't, so I guess I'll repost it.  My movieclip animation is replaying when the playpause_btn is pressed, but I don't want it to replay if the movieclip has already played.
      I don't know where to put the code that checks to see if content2anim_mc has played through its _totalframes, and if it has, to make sure not to play it again.
      playpause_btn.onRelease = function() {
          if (audioplay == true) {
              p = Math.round(_root.Sound2.position/1000);
              _root.Sound2.stop();
              audioplay = false;
              play_mc._visible = true;
              pause_mc._visible = false;
              content2anim_mc.stop();
          } else {
              _root.Sound2.start(p,0);
              audioplay = true;
              pause_mc._visible = true;
              play_mc._visible = false;
              content2anim_mc.play();
      I was thinking something like this code below???
      var mcDone:MovieClip = content2.content2panel.content2anim_mc;
          if (content2anim_mc._currentframe = _totalframes) {
      Thanks again!
        • 1. Re: Still need help with play and pause
          Try:
                  audioplay = false;
              } else {
                  audioplay = true;
                 if(content2anim_mc._currentframe < content2anim_mc._totalframes ){
          • 2. Re: Still need help with play and pause
            eapre Level 1
            Thanks, that worked and now my movieclip does not replay.  I discovered something else wrong though!  I've discovered that there's a problem with toggling between pressing the replay button and the play/pause button.  I press replay, then play/pause, then replay, then play/pause again and the audio starts playing twice.  Maybe it's because I'm using both audioplay = true; AND _root.Sound2.start
            Also, I've got the play icon and the pause icon as two different movieclips (they don't do anything) on top of the main playpause_btn that are made visible and invisible depending on when playpause_btn is clicked.  It's kind of a complicated sloppy-looking way to do it...
            Maybe there's a totally different and better/easier way I can go about this?
            //audio
            audioplay = true;
            _root.Sound2.start(0, 0);
            //replay button
            replay.onRelease = function() {
                stopAllSounds();
                content2anim_mc.gotoAndPlay(1);
            //playpause button
                    audioplay = false;
                } else {
                    _root.Sound2.start(
            p,0);
                    audioplay = true;
            Thanks for being patient here, it's a learning experience
