6 Replies Latest reply on Jul 8, 2009 6:43 AM by kglad
    dynamic generated tabs from array, can't get incremented values for button action
    Bit Crusher
      Hi -
      Here's the setup:
      I have a basic array that has 6 values in it (i.e. the tab labels).
      The tabs are generated without a problem and when I view the objects all six show.  For example:
      Movie Clip: Frame=1 Target="_level0.tabsMC6"
      so that's cool.
      Now when I go to set up the button action for these babies, if I use the _level0.tabs.MC6 then sure, I can fire off button action(s) for that tab or any if I change the tabsMC value.  What I want to do is try to cut down on the code and have the tab value increment, but the best I've been able to achieve is having the last tab work.  The interesting thing is that if I try any of the other tabs (1-5) they all fire off tab #6.
      What I have right now is:
      function tabCount():Void{
          for (i=0; i<_root.slideContainerMC.tabList.length; i++) {
              _level0["tabsMC"+ i].clickerMC.onRollOver = function(){
              _level0["tabsMC"+ i].gotoAndStop("on");
      (side note:  tabList is the array I mentioned above and yes, it is in another MC, which = code all over the place however I am in a rush)
      What I need for some guidance is how to get all of the tabs to have individual button actions.  I thought that the above script woul then have button actions for
      tabsMC1
      tabsMC2
      tabsMC3
      tabsMC4
      tabsMC5
      tabsMC6
      which it doens't do exactly.  tabsMC6 is the only tab that will show the "on"state - I can roll over any of them and that's the only tab that shows this rather than EACH tab showing a state.
      Seems like I'm missing the obvious!
      Thanks!
        • 1. Re: dynamic generated tabs from array, can't get incremented values for button action
          if  _level0.tabs.MC6 is a typical (correct) reference, use:
                 _level0.tabs[MC"+ i].ivar = i;  // <-- which you'll probably need at some point
                 _level0.tabs[MC"+ i].clickerMC.onRollOver = function(){
                      this._parent.gotoAndStop("on");
          tabsMC1
          tabsMC2
          tabsMC3
          tabsMC4
          tabsMC5
          tabsMC6
          Thanks!
          • 2. Re: dynamic generated tabs from array, can't get incremented values for button action
            Bit Crusher Level 1
            cool - the syntax you had posted needed to be finessed (threw up some errors at first) so now it looks like:
                   _level0["tabsMC"+ i].ivar = i;
                    _level0["tabsMC"+ i].clickerMC.onRollOut = function(){
                        this._parent.gotoAndStop("off");
                    _level0["tabsMC"+ i].clickerMC.onRelease = function(){
                        this._parent.gotoAndStop("onPress");
            and yep, this works although tabs 1-5 now function properly, tab #6 is inactive.  Since the array length is six values (0-5) is this what's causing the last tab not to receive it's MC number?
            Another question that I do have from your code (thanks again by the way) - what does the
            produce?  the one part that's throwing me off is
            ivar = i;
            I don't think I've come across that and it's a bit confusing.
            Thanks again!
            • 3. Re: dynamic generated tabs from array, can't get incremented values for button action
              you're defining tabMC0,...,tabMC5.  if you want tabMC1,...,tabMC6 use:
                  for (i=1; i<=_root.slideContainerMC.tabList.length; i++) {
              and the ivar part was anticipating that you would need the ith tab to know it's the ith tab.  ivar stores the value of i used when that particular tabMC was created.  if you don't need that, remove it.
              • 4. Building editable lists
                jntt1211
                Dear friends , can you please tell me how to build a set of list boxes using the user interface components in flash . So that i can enter data into one and move that entered data to anther and send all the obtained data values to my database. A simple example of what i'm trying to acheive is shown below.
                Looking forward for your reply!
                Thanks & Rgds
                jntt1211
                • 5. Re: dynamic generated tabs from array, can't get incremented values for button action
                  Bit Crusher Level 1
                  Perfect!  I tried changing i=1 yesterday with the same results but by adding in that equal to or less than that did the trick...which makes sense.
                  Thank you my friend for solving another problem!
