0 Replies Latest reply on Jul 7, 2009 7:00 PM by Gaurav J
    [svn:fx-trunk] 8441: Removing warning for "signed rsls not supported".
    Gaurav J Adobe Employee
      Revision: 8441
      Author:   gauravj@adobe.com
      Date:     2009-07-07 19:00:28 -0700 (Tue, 07 Jul 2009)
      Log Message:
      Removing warning for "signed rsls not supported". There was a bug in the original implementation and it was generating the warning even when the target player version was 10.0.0
      Also since for flex 4 the minimum required player version is 10, the warning was no longer required.
      This should also get mxmlcunit test passing again.
      QE Notes: None.
      Doc Notes: None.
      Reviewer: will be Darrell
      tests: checkintests
      Modified Paths:
          flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/common/Configuration.java
          flex/sdk/trunk/modules/compiler/src/java/flex2/tools/PreLink.java
          flex/sdk/trunk/modules/compiler/src/java/flex2/tools_en.properties
