1 Reply Latest reply on Jul 8, 2009 7:29 AM by kglad
    problem with a cicle
    pao69
      Hi, everybody. I've a problem with a cicle in flash cs4.
      I have created a function for charge 9 swf movie in random mode. The problem is that every cicle the memory fills and after a few cicle the movie slows.
      I need to reset the function, but I don't know how.
      This is the code:
      var origine:Array = new Array;
      var temp:Array = new Array;
      var r:Number = 1;
      for(var e:Number = 1; e < 10; e++ ) {
          origine[e] = e;
      var estrazione:Array = new Array;
      var n:Number = 0;
      for(var i:Number = 0; i < origine.length; i++) {
          var rand:Number = Math.abs(Math.random() * origine.length);
          estrazione.splice(n, 0, origine.splice(rand, 1));
          i--;
          n++;
      for(i = 0; i < 10; i++) {
          if(estrazione[i] == 0) {
              estrazione[i] = 10;
      function carica():void {
          var imageRequest:URLRequest = new URLRequest("movie"+estrazione[r]+".swf");
          var imageLoader:Loader = new Loader();
          imageLoader.load(imageRequest);
          addChild(imageLoader);
      carica();
      var slide:Timer = new Timer(5000);
      slide.addEventListener(TimerEvent.TIMER, slider);
      function slider(event:TimerEvent):void {
          r++;
          if(r >= 10) {
              r = 1;
          carica();
      slide.start();
      thanks in advance.
        • 1. Re: problem with a cicle
          try:
          var r:Number = 1;
              origine[e] = e;
          var n:Number = 0;
              i--;
              n++;
                  estrazione[i] = 10;
          if(imageLoader!=null){
          removeChild(imageLoader);
          iomageLoader=null;
             imageLoader = new Loader();
          carica();
              r++;
              if(r >= 10) {
                  r = 1;
              carica();
          slide.start();
          thanks in advance.
