0 Replies Latest reply on Jul 8, 2009 6:41 AM by RobohelpUser2k
    <mapID> target attribute is inconsistent
    RobohelpUser2k
      I'm using Robohelp HTML 8 to generate help files for Oracle Help.
      When I am using the Robohelp IDE to create help files for Oracle Help, the generated map file has map targets with title casing, such as this below:
      <map version="1.0">
        <mapID target="Topic_One" url="Topic_One.htm" />
      </map>
      When I use the command line rhcl.exe command (for automating the creation of Oracle Help files) from a script, the generated map file has map targets with lower casing, such as this below:
      <map version="1.0">
        <mapID target="topic_one_htm" url="Topic_One.htm" />
      </map>
      I'm not sure if this is normal behavior...I would like the output Oracle Help map file to have the same casing, regardless of which method is used to generate it...
      Am I missing some additional parameters to the command line that would force normal casing of mapID?
