1 Reply Latest reply on Sep 7, 2009 2:33 AM by liedzeit
    xpath behaves differently in CS4?
    liedzeit Level 2
      Using the bookstore example from the Tools guide I get different results using this code with CS 3 and CS4
      var Docdatafile=File("/test.xml");
      var myResult = Docdatafile.open("r", undefined, undefined);
      var temp = Docdatafile.read();
      var docdata=new XML (temp);
      book=docdata.xpath("//title[@lang]");
      alert(book);
      CS3 gives me "enenenen" which is what I expect whereas CS4 returns the complete title object. I am not completely sure what xpath is supposed to return in this case. (Actually I need to get the name of a publication where name is an attribute of a publication node.)
      To formulate differently: Is there a way to get the attribute name out of an XML object with xpath that works the same way in CS3 and CS4?
      Thank you,
      Ralf
