0 Replies Latest reply on Jul 8, 2009 10:14 AM by Chet Haase
    [svn:fx-trunk] 8455: Fixed various effects bugs.
    Chet Haase Level 3
      Revision: 8455
      Author:   chaase@adobe.com
      Date:     2009-07-08 10:14:01 -0700 (Wed, 08 Jul 2009)
      Log Message:
      Fixed various effects bugs. Includes:
      - fix when setting transform center on effect to (0, 0, 0)
      - fix for transform effects running within a Sequence (they now run independently, instead of combining into a signle instance as they do in a Parallel effect)
      - fix for asdoc error in AnimateTransform3D for applyLocalProjection
      - fix in Resize where we were not setting up propertyChanges correctly for the targets affected by the effect
      - fixes in AnimateTransformInstance to handle scaling in Z correctly and handling translation 'by' effects correctly
      Bugs: sdk-21877, sdk-21610, sdk21584, sdk-21786
      Doc Notes: fixed AnimateTransform3D.applyLocalProjection docs
      QE Notes: may affect Sequence tests with transform effects (since it now actually works), but no failures in current mx/effects/Sequence tests. 11 failures overall in Mustella, some known, the rest Matt will exclude and investigate.
      Reviewer: Jason (plus Ely for AdvancedLayoutFeatures changes)
      Tests: checkintests, Mustella spark/effects, mx/effects/Sequence
      Ticket Links:
          http://bugs.adobe.com/jira/browse/sdk-21877
          http://bugs.adobe.com/jira/browse/sdk-21610
          http://bugs.adobe.com/jira/browse/sdk-21786
      Modified Paths:
          flex/sdk/trunk/frameworks/projects/framework/src/mx/core/AdvancedLayoutFeatures.as
          flex/sdk/trunk/frameworks/projects/spark/src/spark/effects/AnimateTransform.as
          flex/sdk/trunk/frameworks/projects/spark/src/spark/effects/AnimateTransform3D.as
          flex/sdk/trunk/frameworks/projects/spark/src/spark/effects/Resize.as
          flex/sdk/trunk/frameworks/projects/spark/src/spark/effects/supportClasses/AnimateTransfor mInstance.as
