2 Replies Latest reply on Jul 10, 2009 5:17 AM by nhumby
    Proplem with opening documents with Reader 9.1
    mikehak
      Hello Together.
      I hope someone can help me.
      I have a interesting problem. When i want open a PDF Document with a doubleclick, then the Reader hangs most time. This will happen on different documents. If i open this document over Acrobat Reader menu, the document will open correctly.
      The next crazy point is, if i want rename the folder which contains the pdf files, the explorer will hang also.
      Our configuration.
      Windows Vista SP1 and SP2
      Profile Path local
      Adobe Reader 9.1.2
      Domain Logon.
      What i have tested:
      - Same installation with a local user account. = Works.
      - Reinstall = problem exists
      I have found a small thing. If i delete the UserCache.bin file int the APPDATA, then it works until the files is recreated.
      Other PDF reader from other companies works without any problem.
      I hope somebody can give me some hints or a solution for this problem.
      Greets
      Mike
