5 Replies Latest reply on Jul 8, 2009 4:22 PM by the_wine_snob
    Sharp Pictures for Slide Show
    X-Gino-X
      I am trying to use Premiere Elemments to create a slide show from pictures taken with a digital camera. When I import the pictures they are clear and sharp - the same way they appear when I view them individually using other tools. When I put them together is a show they all lose the sharpness. FYI, I have the same results with several other "movie makers."  Am I using the right tools? Is there a fix for this "problem," some where in this 500M program?
      Rich, a.k.a., X-Gino-X
        • 1. Re: Sharp Pictures for Slide Show
          the_wine_snob Level 9
          This ARTICLE in the FAQ will give you a good starting point.
          Let us know if it helps.
          • 2. Re: Sharp Pictures for Slide Show
            X-Gino-X Level 1
            Thanks, this is helpful.  Now at least, I understand why none of these programs is giving me the results I am looking for. Now, how do I resize my photos to try this out?  FYI, I just tried Power Point and have all the original quality without the added step. Of course Power Point doesn't have all the features I am looking for, but I was able to do most everything I wanted in a very short time.  I am certain that Power Point isn't converting the data to a video format and I won't be able to write the output to a DVD, but I will be able to show Slide Shows using my computer to drive my HD TV.
            Thanks again,
            Rich
            • 3. Re: Sharp Pictures for Slide Show
              Check out this ARTICLE in the Tips & Tricks sub-forum. This is how I do it. There could well be other workflows, using other image processing programs, but I really like the results from Photoshop, and assume that almost everything is in PSElements too.
              • 4. Re: Sharp Pictures for Slide Show
                X-Gino-X Level 1
                I tried this rather long process using what I had available - Elements 2.0 a PS tool. The results were the same - lose of quality when transfering picture into video. I think that I'll give up on Adobe Premiere at this time. Thx for all the help. At least now I know what the problem is.
                Best of luck,
                Rich
                • 5. Re: Sharp Pictures for Slide Show
                  About the best that you will be able to do is create an HD Project, resize to that, Import and edit, then Burn to a Blu-ray Disc. Even then, you are limited to the frame sizes of the BD.
                  If PowerPoint is giving you what you want, then that would be my answer too.
