1 Reply Latest reply on Jul 8, 2009 7:53 PM by zistheman
    Problem submitting PDF via HTTPS
    zistheman
      I'm an Adobe Acrobat newbie, and am having issues submitting a PDF form to an HTTPS server.  My basic setup is as follows:
      1)  PDF Form with one text field and a single submit button pointing to a https URL.  The button submits in the XDP format.
      2)  A server which can only be accessed through SSL and has a valid SSL certificate
      I get the following error when I hit the submit button in Adobe Reader 9:
      "An error has occurred during the submit process.  The server has an invalid SSL certificate."
      I tried the following:
      1)  Adding the SSL certificate to the Manage Trusted Identities, and pressing the submit button.  Same error.
      2)  After installing the certificate, going to Edit -> Preferences -> Security -> Advanced Preferences, and checking the box for Enable searching the Windows Certificate store for certificates other than your own.  Same error.
      I've tested the servlet by posting through a .NET application and it works fine. Am I missing something here?
        • 1. Re: Problem submitting PDF via HTTPS
          zistheman Level 1
          I've fixed this problem.  Turns out my windows certificate store didn't have the Root certificate for my website added in it.  I just found the root certificate online and installed it into the "Trusted Root Certification Authorities" store in windows.  I then went to Edit -> Preferences -> Security -> Advanced Preferences, and checked the box for Enable searching the Windows Certificate store.  Works like a charm now.
