2 Replies Latest reply on Jul 9, 2009 9:42 PM by zubinshi
    panel expand problem in viewstack
    zubinshi
      If there are 2 panels in a view stack. one of the panel will dynamically adding and removing components.  The problem I am facing now is the while adding and removing component in panel, the panel doesn't expand automatic(if it is not inside the view stack, it works fine). Please help me out. thanks.
      Following are the sample codes you can run:
      <?xml version = "1.0" encoding = "utf-8"?>
      <mx:Application
      xmlns:mx = "http://www.adobe.com/2006/mxml
      layout = "
      vertical
      verticalAlign = "
      middle
      horizontalAlign = "
      center
      backgroundGradientColors = "
      [0x000000,0x323232]
      viewSourceURL = "
      srcview/index.html"
      <mx:Script>
      <![CDATA[
      private function changePanel():
      void
      if
      (viewStack.selectedChild == loginPanel)
      viewStack.selectedChild = anotherOne
      else
      viewStack.selectedChild = loginPanel;
      </mx:Script>
      <!-- The Application class states property defines the view states.-->
      <mx:states>
      <mx:State name = "Register"
      <!-- Add a TextInput control to the form. -->
      <mx:AddChild relativeTo = "{loginForm}
      position = "
      lastChild"
      <mx:FormItem id = "confirm
      label = "
      Confirm:"
      <mx:TextInput/>
      </mx:FormItem>
      </mx:AddChild>
      <!-- Set properties on the Panel container and Button control.-->
      <!-- Remove the existing LinkButton control.-->
      <mx:RemoveChild target = "{registerLink}"
      <!-- Add a new LinkButton control to change view state
      back to the login form.-->
      <mx:AddChild relativeTo = "{spacer1}
      position = "
      before"
      <mx:LinkButton label = "Return to Login
      click = "currentState=
      </mx:AddChild>
      </mx:State>
      </mx:states>
      <mx:VBox width = "100%
      height = "
      100%"
      <mx:ViewStack id = "viewStack
      width = "
      100%
      creationPolicy = "
      all"
      <mx:Panel id = "anotherOne
      width = "
      100%
      title = "
      test"
      <mx:VBox>
      <mx:Button label = "test
      width = "
      100%"
      width = "
      100%"
      </mx:VBox>
      </mx:Panel>
      <mx:Panel id = "loginPanel
      width = "
      100%
      title = "
      Login"
      <mx:VBox id = "loginForm
      width = "
      100%"
      <mx:HBox>
      <mx:Button label = "a"
      <mx:Button label = "b"
      </mx:HBox>
      <mx:Button label = "c"
      </mx:VBox>
      <mx:ControlBar width = "100%"
      <!-- Use the LinkButton to change to the Register view state.-->
      <mx:LinkButton id = "registerLink
      label = "
      Need to Register?
      'Register'"
      <mx:Spacer width = "100%
      id = "
      spacer1"
      <mx:Button label = "Login
      id = "
      loginButton"
      </mx:ControlBar>
      </mx:Panel>
      </mx:ViewStack>
      <mx:Button id = "changeButton
      label = "
      change
      click = "changePanel()"
      </mx:VBox>
      </mx:Application>
