2 Replies Latest reply on Jul 9, 2009 1:50 PM by okvideoguy
    Best workflow for multi-cam edit with multi-track sound?
    hyalinejim
      Hi All,
      This is my situation:
      I'm doing a short film where I need to edit a number of separate interviews I have shot. Each interview was two people at the same time. I had two cameras, one wide static shot showing both interview subjects and the other close, panning as required. The externally recorded sound was a mono mic on each person into the left and right channels of a stereo recorder.
      This is my my question:
      What is the best way to edit all this? I have tried the multi-cam workflow but I have had problems with it. Each interview has its own sequence with Camera A and B on tracks one and two. The sound is duplicated on Audio 1 and 2, except with a Fill Left and Fill Right to isolate the relevant mic. If I use the multi-cam workflow then I only get Audio Track 1. I know that there is an option to switch audio with each camera cut, but that is no good because the audio won't change just because I switch from a wide to a close shot. When one person is talking I want to mute the other person's mic.
      To be honest it would be ideal if I could work with the copies of the original files from the interview sequences instead of nesting sequences. This is because I shot in 1080 and am outputting in 720 and will be doing some reframing. If I work with nested sequences then I have to go back to my original sequence, finding the in and out points of the relevant bit and do my motion transforming there and then return to the nested sequence to continue editing. I think it would be easier working with copy and pasted clips. The only problem is that I can link the audio clips and one video clip, but not all four!
      Can anyone suggest an elegant solution? This is a fairly  major project (around 14 hours of interview footage) so any help would be greatly appreciated!
        • 1. Re: Best workflow for multi-cam edit with multi-track sound?
          hyalinejim Level 1
          I think I have found a solution for the audio that will work, although I still don't know if this is the best solution.
          I leave the external stereo audio as one track on the pre-nested sequences. In the multicam sequence I can drop the Fill Left or Fill Right effect onto the audio clip depending on who is talking. If I need to pan audio, I cut the clip and put the opposite Fill effect on the next clip and put an audio transition between them.
          It still doesn't solve the problem of having to go back to the original sequences in order to use the Motion controls to reframe. This is indeed fairly tedious as it involves finding the point in the multicam sequence that I want reframed, pressing M, copying the timecode in the source window, going back to the pre-nested sequence, pasting the timecode in the timeline window, making a cut, adjusting scale and position. And possible finding the out point and reverting to the default.
          Does this sound like madness?
          • 2. Re: Best workflow for multi-cam edit with multi-track sound?
            Level 1
            When shooting weddings, we will have from three to six video tracks and a half-dozen audio tracks.  I'll skip the explanation of getting six v tracks boiled down to four, since it is irrelevant to your question..
            I take the audio file with the most information (i.e.: enough sound to figure out what is going on) and place it on track #1 in my source sequence.  When I'm finished cutting the multi-track source video, and before cutting out any of the target sequence video, I turn off audio track #1 in the target sequence (or just delete the track) and copy all the audio tracks from the source sequence into the target sequence.  Any stereo tracks that had different mics, I'll copy twice and use left or right fill as you've done, to isolate the mics.  Often I'll rubberband the audio tracks so I don't pickup from the further mics, etc.
            With only two cameras, you may be just as well off laying one video track over the other and cutting away the upper track as needed ala PP 6.5, but when using three or four cameras, the multi-cam feature sure comes in handy.
            Don't forget to sweeten your audio a bit with the compression feature of the dynamic processing options.
