4 Replies Latest reply on Jul 10, 2009 1:56 AM by _Natasha_
    adding child to a itemrenderer without overlapping the already existing child
    flx23 Level 1
      i am adding an image to a component(itemrenderer)..but the problem is that it overlapps the already existing control which is also an image
      the itemrenderer is generating 10 images the problem is arise when i use to add the dynamically generated image on the top of the already existing 10 images..it overlaps the first one...
      how can i add the new image without overlapping the already existing image....like the way we do in array with the splice method whose syntax is :-
      planets.splice(1, 0, "Venus", "Earth");
      where 1 is the index position and 0 says not to delete any existing value from array
      (do we have any method like this in case of adding control to a componet if no ..is there any other way to do this)
      the image i am adding .is being generated dynamically as following:-
      [Embed(source="Assets/top_img.png")]
              private var imgtop:Class;
                     var img:Image=new Image();
                      img.height=48;
                      img.width=383;
                      img.source=imgtop;
                     this.child(img);
