9 Replies Latest reply on Jul 9, 2009 12:33 PM by kglad
    preloader problem with random image loader
    heazle
      I would like for the website preloader to recognize the random image loader that I have on frame 8 of my site
      I have a basic preloader on frames 1 and 2
      (frame 1)
                    var amountLoaded:Number=_root.getBytesLoaded()/root.getBytesTotal;
      (frame 2)
                    if(_root.getBytesLoaded()==_root.getBytesTotal()}
                    gotoAndStop(8);)\\\\beginnig of site
                    else (gotoAndPlay(1);}
      I have tried putting the random image loader on frame 1 or 8 and the preloader doeas not recognize it
      The random image loader is an empty movieclip that is in the center of the screen and has has code on frame 1 of it and an object with an instance name of location.
                    choise=Math.round(Math.random()*16);
                    switch (choise)  {
                    case 0:
                               location.loadMovie("image1.jpg")
                               break;
                    case 1:
                               location.loadMovie("image2.jpg")
                               break;          \\\\\\\and so on.
      the random image loader works great besides the fact that I cant get the preloader to recognize it
        • 1. Re: preloader problem with random image loader
          you'll need to create separate preloader code for the image loader.
          • 2. Re: preloader problem with random image loader
            heazle Level 1
            Do I put that code in the movie clip with the random image code?
            • 3. Re: preloader problem with random image loader
              put the preloader code in the same frame with the location.loadMovie() code.
              • 4. Re: preloader problem with random image loader
                heazle Level 1
                It didn't work but Im sure my code is off
                This is what I have in the first frame of the movie clip
                choice = Math.round(Math.random()*16);
                switch (choice) {
                     case 0 :
                          location.loadMovie("image0.jpg");
                          break;
                     case 1 :
                          location.loadMovie("image1.jpg");
                          break;
                     case 16 :
                          location.loadMovie("image16.jpg");
                          break;
                var amountLoaded:Number= _root.getBytesLoaded()/root.getBytesTotal;
                if(_root.getBytesLoaded() == _root.getBytesTotal())
                     _parent.gotoAndStop(8);
                else {
                     gotoAndPlay(1);
                • 5. Re: preloader problem with random image loader
                  switch (choice) {
                       case 0 :
                            location.loadMovie(" image0.jpg");
                            break;
                       case 1 :
                            location.loadMovie(" image1.jpg");
                            break;
                       case 16 :
                            location.loadMovie(" image16.jpg");
                            break;
                  clearInterval(preloadI);
                  preloadI=setInterval(preloadF,100);
                  function preloadF(){
                  var amountLoaded:Number= location.getBytesLoaded()/location.getBytesTotal;
                  if(amountLoaded==1)
                  // loading is complete.  do whatever.
                  else {
                  // loading is not complete.  display preload info/graphics
                  • 6. Re: preloader problem with random image loader
                    heazle Level 1
                    This is what I entered
                    Flash didn't like the
                      Function preloadF()
                    if(amountLoaded==1)
                    {_parent.gotoAndStop(8);
                    else {gotoAndPlay(1);}
                    • 7. Re: preloader problem with random image loader
                      1.  it looks like you missed a function closure - }
                      2.  don't use a frame loop with that code.
                      • 8. Re: preloader problem with random image loader
                        heazle Level 1
                        I think I almost have it, the only thing I am having trouble figuring out is the else {} I want it to play a movie clip "preload 1" in the right x, y corrdinate
                        And I want it to goto fame 8 of the parent movie clip whan done.
                        switch (choice) {
                             case 0 :
                                  location.loadMovie("Simage0.jpg");
                                  break;
                             case 1 :
                                  location.loadMovie("Simage1.jpg");
                                  break;
                             case 16 :
                                  location.loadMovie("Simage16.jpg");
                                  break;
                        if(amountLoaded==1)
                        else {}
                        • 9. Re: preloader problem with random image loader
                          switch (choice) {
                               case 0 :
                                    location.loadMovie(" Simage0.jpg");
                                    break;
                               case 1 :
                                    location.loadMovie(" Simage1.jpg");
                                    break;
                               case 16 :
                                    location.loadMovie(" Simage16.jpg");
                                    break;
                          if(amountLoaded==1)
                          else { preload1.gotoAndStop(Math.ceil(100*amountLodaed))}}  // if preload1 has 100 frames and displays the load progress
