1 Reply Latest reply on Jul 9, 2009 12:44 PM by java the hutt
    Licensing problem
    java the hutt Level 1
      When I try to start Flash Builder 4 on Mac, I get the error message "Licensing for the product has stopped working".  Could this be because I use a case-sensitive filesystem?  I've never had this problem with Flex Builder 2 or 3.
        • 1. Re: Licensing problem
          When I install Flash Builder to a disk image formatted with a case-insensitive filesystem, I have no problem starting Flash Builder.  So it appears Flash Builder no longer supports case-sensitive filesystems.  This is a real bummer.  Can Adobe please fix this before final release?  It can't be that hard.  It's probably a matter of fixing some filename cases in the installer.
          Thanks.
