0 Replies Latest reply on Jul 9, 2009 4:38 PM by GordonSmith
    [svn:fx-trunk] 8499: TextAreaSkin no longer has a minimum size.
    GordonSmith Level 4
      Revision: 8499
      Author:   gosmith@adobe.com
      Date:     2009-07-09 16:38:35 -0700 (Thu, 09 Jul 2009)
      Log Message:
      Glenn approved this change, despite the fact that the XD specs call for a minimum size of 36, because it was causing bugs such as SDK-16008 and SDK-20993. You might, for example, want a two-line TextArea whose height is less than 36 pixels.
      A non-zero minimum size was first introduced in revision 6808 to fix bugs SDK-19785 and SDK-19807. But the underlying cause of these bugs -- infinite invalidation loops caused by Scroller trying to figure out whether to put up scrollbars or not -- has been fixed in Scroller by Hans.
      This change is only part of the fix for SDK-20993; Scroller seems to be imposing a non-zero minimum size as well. Hans will make Scroller allow any size and hide its scrollbars if there isn't room for them.
      QE Notes: SDK-19786 and SDK-19807 should be retested
      Doc Notes: None
      Bugs: SDK-16008, part of SDK-20993
      Reviewer: Carol to review
      Ticket Links:
          http://bugs.adobe.com/jira/browse/SDK-16008
          http://bugs.adobe.com/jira/browse/SDK-20993
          http://bugs.adobe.com/jira/browse/SDK-19785
          http://bugs.adobe.com/jira/browse/SDK-19807
          http://bugs.adobe.com/jira/browse/SDK-19786
      Modified Paths:
          flex/sdk/trunk/frameworks/projects/spark/src/spark/skins/spark/TextAreaSkin.mxml
