8 Replies Latest reply on Aug 2, 2009 11:43 AM by the_wine_snob
    AVCHD Video appear grainy "sawtooth" on playback after rendering
    bk12345
      I'm using a Canon VIXIA HG20 AVCHD HD Video Camcorder and have been shooting in 1080/60i with a 1920x1080 Image Resolution at 24Mbps.
      I copied the MTS files on to my dedicated Video drive and opened Elements 7 and started a project using the "NTSC AVCHD 1080i 30" setting.
      Setting states the following:
      - For editing with 1920x1080i AVCHD camcorders.
      - 16:9 interlaced HD video at 29.97 frames per second.
      - 48kHz audio.
      - Drop-Frame Timecode numbering.
      General Editing mode: HD 1080i Timebase: 29.97 fps
      Video Settings Frame size: 1920h 1080v (1.000)
      Frame rate: 29.97 frames/second
      Pixel Aspect Ratio: Square Pixels (1.0)
      Fields: Upper Field First
      Audio Settings
      Sample rate: 48000 samples/second
      Capture Format HDV Capture
      Video Rendering
      Maximum Bit Depth: Off (Also tried with it on)
      Preview File Format: I-Frame only MPEG-2
      Compressor: I-Frame Only MPEG
      Color depth: Millions of colors
      Default Timeline Video tracks: 3
      Stereo tracks: 3
      I added the media files and previewed them i the monitor and also on the timeline and they looked great!
      I then rendered the video (by pressing the Enter key) and noticed the video did not look nearly as good afterwards during playback. The video seems to have "saw-toothed" like pixels on some of the moving objects on playback, such as on the edge of a shirt collar (just an example), yet appears great again when paused.
      I've tried to monkey-around with the settings, yet to no luck.
      Any thoughts about why this is happening and what can be adjusted to correct the issue?
      Thank you, Brandon
