2 Replies Latest reply on Jul 9, 2009 9:15 PM by Benoitcn
    Java data send to flex issue
    Benoitcn Level 1
      This is my data structure at back-end using java,
      ArrayList
                HashTable(keys, values);
      but the problem is when push the data to flex this data structure will be coverd to a instance of ArrayCollection and the HashTable covered to a Object.
      HashTable is out-of-order so the order of my data in flex is different every time . I use the ArrayCollection bind to the DataList component directly, and I don't want to indicate the order of each columns of  each DataList Component.How can I fix this ?
      var dataSource:ArrayCollection = from Java back-end;
      <mx:DataList dataProvider="{dataSource}" />
      I don't want to indicate each columns like this, because I have a lot of different structure tables in SQL.
      <mx:DataList dataProvider="{dataSource}" >
          <mx:DataListColumns dataField="ID" />
          <mx:DataListColumns dataField="Name" />
          <mx:DataListColumns dataField="Age" />
          <mx:DataListColumns dataField="Address" />
      </mx:DataList>
