4 Replies Latest reply on Jul 10, 2009 5:18 AM by meshgraphics
    How to run the ASDoc XSLT transformation manually?
    mech-head
      Hello there,
      I am combining the XML (toplevel.xml and toplevel_classes.xml) output of several actionscript projects into
      a one central XML file. I do this by first running the asdoc tool on the separate projects with the keep-xml and
      skip-xsl switches set to true. I then run my own XSLT script that combines the toplevel XML files and
      toplevel_classes XML files into two main files.
      After that I'd like to run the actual HTML generation, as far as I know its not possible to run asdoc with certain
      switches that tell it to skip the XML generation and just perform the XSLT transform immediately for a specified
      toplevel.xml and toplevel_classes.xml.
      Therefore I guess I have to run the XSLT tranforms from the 'templates' directory myself.
      So, thus my question is, what is the exact order of XSLT transforms and for which files?
      i.e. do I call class-list.xsl with toplevel_classes.xml, etc?
      thanx a lot in advance,
      Roland
