8 Replies Latest reply on Jul 10, 2009 8:10 AM by ma.tze
    How to convert evt.result value into ArrayCollection
    Raghuvasa
      Hi All,
               i am getting object from databse as evt.result in ActionScript method.
               i have to assign this evt.result to ArrayCollection variable.
               [Bindable]
              public var dp:ArrayCollection;
              this is dp is ArrayCollection variable. i want to assign evt.result into dp
              How can i do it. any one can help me.
      Raghu.
        • 1. Re: How to convert evt.result value into ArrayCollection
          _Natasha_ Level 4
          what is the type of this result?
          In result event handler you should write
          dp = new ArrayCollection(event.result); // if event.result is an Array
          dp = ArrayCollection(event.result); // if event.result is already an ArrayCollection.
          Also you can bind with lastResult (if data is from HTTPService)
          • 2. Re: How to convert evt.result value into ArrayCollection
            Raghuvasa Level 1
            Hi Natasha,
            i am calling a method getData in java class through Remote Object like this way
            <mx:RemoteObject id="empservice" showBusyCursor="true" destination="emp">
                        <mx:method name="getData" result="resultHandler(event)" />
                </mx:RemoteObject>
            //--------Action Script methods.
                  function dbConnection():void{
                        empservice.getOperation('getData').send();
                    function resultHandler(evt:ResultEvent):void{
                        chart.dataProvider = evt.result;
                        ca1.dataProvider = evt.result;
            this is the way  i am doing .
            In resultHandler i am assinging to chart.dataProvider but i want  to assign to ArrayCollection variable.
            How can i do it.
            thanks
            Raghu.
            • 3. Re: How to convert evt.result value into ArrayCollection
              _Natasha_ Level 4
              Chart dataProvider can be Array and ArrayCollection, so I can't understand what type do you have. By default from RemoteObject data returned as Array.
              So first try
              But also you can try
              If event.result is Array dp will be null.
              • 4. Re: How to convert evt.result value into ArrayCollection
                Raghuvasa Level 1
                Hi Natasha,
                                   Thanks for your replies. pls dont hesitate for my questons becoz i am new to this.
                as u said that i have assigned dp:ArrayCollection = new ArrayCollection(evt.result); but it is showing error
                Implicit coercion of a value with static type Object to a possibly unrelated type Array.
                in resultHanlder
                instead of assigning evt.result to chart.dataProvider i want to assign evt.result to dp. dp is an ArrayCollection variable and i wan to assign like this way
                  <mx:ColumnChart id="chart"   showDataTips="true"  dataProvider="dp">
                how to capture the result returned by the Remote object. and how to assign it to dp. dont forget to see i have mentioned return type as void for action script methods. is there any change pls let me know.
                this is my application
                <?xml version="1.0"?>
                <!-- charts/DrillDownWithEffects.mxml -->
                <mx:Application xmlns:mx="http://www.adobe.com/2006/mxml" height="100%" width="100%" initialize="dbConnection();">
                    </mx:RemoteObject>
                    <mx:Script><![CDATA[
                        import mx.collections.ArrayCollection;
                        import mx.charts.HitData;
                        import mx.charts.events.ChartItemEvent;
                        import mx.rpc.events.ResultEvent;
                        [Bindable]
                    ]]></mx:Script>
                    <mx:Panel id="p1" title="Net Worth">
                         <mx:ColumnChart id="chart"   showDataTips="true" >
                            <mx:series>
                                <mx:ColumnSeries id="cs1"
                                    displayName="States"
                                    yField="States"
                                    xField="States"/>
                                <mx:ColumnSeries
                                    xField="States"
                                    yField="date"
                                    displayName="date" />
                            </mx:series>
                            <mx:horizontalAxis>
                                <mx:CategoryAxis id="ca1" categoryField="States"/>
                            </mx:horizontalAxis>
                        </mx:ColumnChart>
                        <mx:Legend id="myLegend" dataProvider="{chart}"/>
                    </mx:Panel>
                </mx:Application>
                • 5. Re: How to convert evt.result value into ArrayCollection
                  rgadiparthi Level 2
                  Seems your service returns object,
                  Here you can do two things
                  1. Change the service(getOperation('getData')) return type to Array or ArrayCollection.
                  or
                  2. Loop thru your object and create a array or arraycollection by yourself.
                  • 6. Re: How to convert evt.result value into ArrayCollection
                    Raghuvasa Level 1
                    Hi ,
                           Where can i change the return type. and how can i change the return type.
                    Raghu.
                    • 7. Re: How to convert evt.result value into ArrayCollection
                      rgadiparthi Level 2
                      if you have access to service code you can change for the method you are calling.
                      there you need to tweek your code to return Array instead of Object.
                      • 8. Re: How to convert evt.result value into ArrayCollection
                        ma.tze Level 1
                        does this help?
                        dp=event.result as ArrayCollection;
                        By!
                        Martin Zach
