4 Replies Latest reply on Jul 12, 2009 8:46 PM by Dave Saunders
    StoryOffset Page Number
      Using StoryOffset of XmlElement or PI is it possible to get the Page Number?
        • 1. Re: StoryOffset Page Number
          Thomas B. Nielsen Level 3
          var myPageItem = app.activeDocument.pages[0].pageItems[0];
          var myPage = findPage(myPageItem);
          // for page number either use
          var myPageNum = myPage.name;
          // or
          var myPageNum2 = myPage.documentOffset;
          // findPage by Dave Saunders
          function findPage(theObj) {
              var thePage = theObj;
              if (thePage.hasOwnProperty("baseline")) {
                thePage = thePage.parentTextFrames[0];
              while (thePage.constructor.name != "Page") {
                var whatIsIt = thePage.constructor.name;
                switch (whatIsIt) {
                  case "Story" :
                    thePage = thePage.textFrames[-1].parent;
                  case  "Character" :
                  case "Cell" :
                    try {
                      thePage = thePage.insertionPoints[0].parentTextFrames[0];
                    } catch (e) {
                      // must be overset, so ignore
                      return null;
                  case "Application" :
                    // must be off page, so ignore
                    return null;
                thePage = thePage.parent;
              return thePage
          • 2. Re: StoryOffset Page Number
            Dave Saunders Level 4
            This is the latest version of the findPage function that I currently use:
            if (theObj.hasOwnProperty("baseline")) {
            theObj = theObj.parentTextFrames[0];
            while (theObj != null) {
            var whatIsIt = theObj.constructor;
            switch (whatIsIt) {
            case Page : return theObj;
            case Character : theObj = theObj.parentTextFrames[0]; break;
            case Footnote :; case Cell : theObj = theObj.insertionPoints[0].parentTextFrames[0]; break;
            case Note : ; case Footnote : theObj = theObj.storyOffset; break;
            case Application : return null;
            if (theObj == null) return null;
            theObj = theObj.parent;
            return theObj
            } // end findPage
            Bear in mind when calling it that you might get a null return.
            • 3. Re: StoryOffset Page Number
              Harbs. Level 6
              Something's wrong there...
              You have "case Footnote" in there twice.
              • 4. Re: StoryOffset Page Number
                Ooh! So I do. Well, the first one's right so I guess that is the one that was used when I ran this just the other day in a script that was dealing with split footnotes!
                The second instance tells you which page the footnote reference is on but that doesn't help if you're dealing with text in a footnote that flows on to another page and you want to know which page that is.
