0 Replies Latest reply on Jul 10, 2009 7:58 AM by Paul Reilly
    [svn:fx-trunk] 8503: * Updated license.jar, with the Perforce build number in the manifest,
    Paul Reilly Level 1
      Revision: 8503
      Author:   preilly@adobe.com
      Date:     2009-07-10 07:58:17 -0700 (Fri, 10 Jul 2009)
      Log Message:
      • Updated license.jar, with the Perforce build number in the manifest,
        and the code in CompilerAPI, which calls into it.
      tests Passed: checkintests
      Needs QA: YES
      Needs DOC: NO
      API Change: NO
      Is noteworthy for integration: Yes, the automation team should be able
                                     to test licensing.
      Code-level description of changes:
        modules/compiler/src/java/flex2/compiler/CompilerAPI.java
          Modified hasValidLicense() to call isFlashBuilderPremiumValid().
      Modified Paths:
          flex/sdk/trunk/lib/license.jar
          flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/CompilerAPI.java
