3 Replies Latest reply on Jul 10, 2009 11:34 AM by Peter deHaan
    Not getting all the code hints?  4.0.0 7219
    flairjax Level 1
      So what would be the reason I am not getting a lot of code hints for things like mx:DataGrid, mx:ApplicationControlBar and mx:Object?
      TiA
        • 1. Re: Not getting all the code hints?  4.0.0 7219
          flairjax Level 1
          Tried getting the lastest nightly build, setting it to 4.1 as the folder name, went into flex compiler, set use specific to 4.1 mentioned previsouly and clicked apply  and ok.
          I get "Internal Build Error"
          !ENTRY com.adobe.flexbuilder.project 4 43 2009-07-10 11:13:45.390
          !MESSAGE Uncaught exception in compiler
          !STACK 0
          java.lang.ClassCastException: flex2.tools.oem.LibraryCache
               at com.adobe.flexbuilder.multisdk.compiler.internal.GumboConfiguration.applySharedLibraryCache(GumboConfiguration.java:50)
               at com.adobe.flexbuilder.multisdk.compiler.internal.ASBuilder.applySettings(ASBuilder.java:337)
               at com.adobe.flexbuilder.multisdk.compiler.internal.ASApplicationBuilder.setup(ASApplicationBuilder.java:67)
               at com.adobe.flexbuilder.multisdk.compiler.internal.ASItemBuilder.setup(ASItemBuilder.java:54)
               at com.adobe.flexbuilder.project.compiler.BuilderFactory.createBuilder(BuilderFactory.java:80)
               at com.adobe.flexbuilder.project.compiler.BuilderFactory.createBuilder(BuilderFactory.java:59)
               at com.adobe.flexbuilder.project.compiler.BuilderManager.getBuilder(BuilderManager.java:190)
               at com.adobe.flexbuilder.project.compiler.internal.FlexIncrementalBuilder.preBuild(FlexIncrementalBuilder.java:394)
               at com.adobe.flexbuilder.project.compiler.internal.FlexProjectBuilder.buildItem(FlexProjectBuilder.java:421)
               at com.adobe.flexbuilder.project.compiler.internal.FlexProjectBuilder.build(FlexProjectBuilder.java:264)
               at com.adobe.flexbuilder.project.compiler.internal.FlexIncrementalBuilder.build(FlexIncrementalBuilder.java:131)
               at org.eclipse.core.internal.events.BuildManager$2.run(BuildManager.java:633)
               at org.eclipse.core.runtime.SafeRunner.run(SafeRunner.java:37)
               at org.eclipse.core.internal.events.BuildManager.basicBuild(BuildManager.java:170)
               at org.eclipse.core.internal.events.BuildManager.basicBuild(BuildManager.java:201)
               at org.eclipse.core.internal.events.BuildManager$1.run(BuildManager.java:253)
               at org.eclipse.core.internal.events.BuildManager.basicBuild(BuildManager.java:256)
               at org.eclipse.core.internal.events.BuildManager.basicBuild(BuildManager.java:218)
               at org.eclipse.core.internal.events.BuildManager.build(BuildManager.java:360)
               at org.eclipse.core.internal.resources.Project.internalBuild(Project.java:516)
               at org.eclipse.core.internal.resources.Project.build(Project.java:94)
               at org.eclipse.debug.core.model.LaunchConfigurationDelegate.buildProjects(LaunchConfigurationDelegate.java:391)
               at org.eclipse.debug.core.model.LaunchConfigurationDelegate.buildForLaunch(LaunchConfigurationDelegate.java:117)
               at com.adobe.flexide.launching.AbstractFlexLaunchDelegate.buildForLaunch(AbstractFlexLaunchDelegate.java:816)
               at org.eclipse.debug.internal.core.LaunchConfiguration.launch(LaunchConfiguration.java:732)
               at org.eclipse.debug.internal.core.LaunchConfiguration.launch(LaunchConfiguration.java:614)
               at org.eclipse.debug.internal.ui.DebugUIPlugin.buildAndLaunch(DebugUIPlugin.java:880)
               at org.eclipse.debug.internal.ui.DebugUIPlugin$8.run(DebugUIPlugin.java:1083)
               at org.eclipse.core.internal.jobs.Worker.run(Worker.java:55)
          • 2. Re: Not getting all the code hints?  4.0.0 7219
            CoreyRLucier Adobe Employee
            Specific to your crash only...
            There are actually a few threads already spun up on this issue..it's a known bug...just restart Flash Builder and you should be fine?  Just make sure there is only one Flex 4 SDK configured in your Flash Builder workspace as well.
            -C
            • 3. Re: Not getting all the code hints?  4.0.0 7219
              Peter deHaan Level 4
              dallas,
              Re: code hinting,
              You should be getting code hints for DataGrid (I just verified in SDK 4.0.0.8497).
              The mx:Object tag moved to the fx:Object namespace.
              The mx:ApplicationControlBar issue is due to http://bugs.adobe.com/jira/browse/FB-19530
              Peter
