• Global community
    • Language:
      • Deutsch
      • English
      • Español
      • Français
      • Português
  • 日本語コミュニティ
  • 한국 커뮤니티
Exit
0
Searching for Acronyms
New Here ,
Jul 10, 2009 Jul 10, 2009
This may have been answered previously but couldn't find answer. Am using RH7 WebHelp. I have many pages with acronyms in title and body. Searching in RoboHelp by the acronym brings no results, except for a couple of Word docs and .pdfs that have the acronym.
Is there any way for users to be able to search using an acronym? I am upgrading to RoboHelp 8 and am not sure if this is possible with new version.
Thanks!
Views
1.9K
Translate
Translate
Report
Report
Community guidelines
community guidelines
Guest
Hi, Hugh. How are you formatting your acronyms? I am still in RH7 and it seems to be working fine for me.
Are you talking about searching the compiled output, or in the RH project that you work in to create the Help?
How do you format your acronyms?  I searched on GASB and PDF and they came up fine. I don't use periods between the letters - do you (i.e. G.A.S.B.)?
-Laurin
Votes
Translate
Translate
Report
Report
New Here ,
Hi Laurin,
I'm talking about the end users searching the compiled output. For example, I have many pages with "OBM" in title and body. Searching for "OBM" with no periods, only brings up the associated Word docs and .pdf files, none of the html pages containing "OBM".
thanks.
Votes
Translate
Translate
Report
Report
Guest
there may be something else getting in the way, because, as I said, I can search on acronyms quite successfully in my help projects - I have tested a few now.
so how about conditional build tags -do you use them? Could you be excluding topics you didn't expect to, as a result of the build statement you use?
Votes
Translate
Translate
Report
Report
Valorous Hero ,
Hi there
There's a little used feature in RoboHelp that may help with this. You might open the Index designer and list the acronyms there.
Just tell your users it's "Enhanced Search". Not sure who coined that term. LOL
Cheers... Rick
Helpful and Handy Links
Votes
Translate
Translate
Report
Report
Guest
LATEST
Hugh,
In your set of WebHelp files, look for some XML files with "whfwdata" in the file name.  In one particular project's WebHelp output, I've got these files in both a whdata folder and a whxdata folder. I think these files drive the search function.  As a test, see if "obm" (every entry seems to be in lower case) appears in any of those files. Let us know what you find.
Ben
GryphonMountain.net
Votes
Translate
Translate
Report
Report
Resources
RoboHelp Documentation
Download Adobe RoboHelp
