5 Replies Latest reply on Jul 11, 2009 7:52 AM by kglad
    TypeError: Error #2007: Parameter text must be non-null.
    mtataric
      This error comes up every single time I try to run a simple AS3 tutorial flash file on my website..
      Things I did:
      -server php support check was run. (success!)
      -using html to call php for a simple registration form.(success!)
      -ANY flash file to do a two way communication with a php file ( FAILS!)
      I tried maybe 10 different swf files and php files that go with them.. always the same exact error but why?
      The server runs on Linux and supports PHP 5.x!!
      Please give me some suggestions!
      P.S. i use Godaddy free hosting..
      Thanks!
      ~Kaan
        • 1. Re: TypeError: Error #2007: Parameter text must be non-null.
          show your urlloader code and your php code.
          • 2. Re: TypeError: Error #2007: Parameter text must be non-null.
            mtataric Level 1
            sure, here is one of them:
            AS3
            stop();
            // Assign a variable name for our URLVariables object
            var vars:URLVariables = new URLVariables();
            //  Build the varSend variable
            var varSend1:URLRequest = new URLRequest("http://www.yourwebsite.com/scripts/checkuserlog.php");
            varSend1.method = URLRequestMethod.POST;
            varSend1.data = vars;
            // Build the varLoader variable
            var varLoader1:URLLoader = new URLLoader;
            varLoader1.dataFormat = URLLoaderDataFormat.VARIABLES;
            varLoader1.addEventListener(Event.COMPLETE, completeHandler1);
            // Handler for PHP script completion and return
            function completeHandler1(event:Event):void{
                if (event.target.data.return_msg == "not_logged_in") {
                    gotoAndStop(2);
                } else {
                    welcome_txt.text = event.target.data.member_name;
                    gotoAndStop(3);
            vars.post_code = "check_log";
            varLoader1.load(varSend1);
            PHP
            <?php
            session_start();
            // Created BY Adam Khoury @ www.developphp.com
            if ($_POST['post_code'] == "check_log") {
                if (!isset($_SESSION['id'])) {
                      if (!isset($_COOKIE['idCookie'])) {
                           print "return_msg=not_logged_in";
                           exit();
                // connect to DB to update last visit day
                include_once "connect_to_mysql.php";
                // If session ID is set for logged in user
                // The regular session expires by default every time the user closes their browser down
                // If that is the case this section will not run and the section below for recognizing set cookies will run
                if (isset($_SESSION['id'])) {
                $id = $_SESSION['id'];
                $firstname = $_SESSION['firstname'];
                print "id=$id&member_name=$firstname";
                exit();
                // If cookies are set, but no session ID is set yet, we set it below and update the last_log_date field in database
                if (isset($_COOKIE['idCookie'])) {
                $id = $_COOKIE['idCookie'];
                $firstname = $_COOKIE['firstnameCookie'];
                $email = $_COOKIE['emailCookie'];
                $pass = $_COOKIE['passCookie'];
                // Register the session vars just like we do in the login form
                session_register('id');
                $_SESSION['id'] = $id;
                session_register('firstname');
                $_SESSION['firstname'] = $firstname;
                session_register('email');
                $_SESSION['email'] = $email;
                session_register('pass');
                $_SESSION['pass'] = $pass;
                // Access the value of these two session variables for use in sql statement below
                // and also for sending these two vars into the flash header for use and display
                ///////////          Update Last Log Date Field Or not         ///////////////////////////////////////////////////////////////////////////////////////// ////////////////////////////////////////
                // Check last visit date does not equal today
                $sql1 = mysql_query("SELECT last_log_date FROM myMembers WHERE id='$id'");
                while($row = mysql_fetch_array($sql1)){
                    $last_log_date = $row["last_log_date"];
                // This sets today's date format that will be matching that of the var below coming from mysql
                $today = date("Y-m-d");
                // this makes the date the same format as the today date var format for easy comparison of the two
                $last_log_date = strftime("%Y-%m-%d", strtotime($last_log_date));
                if ($last_log_date != $today) {
                      mysql_query("UPDATE myMembers SET last_log_date=now() WHERE id='$id'");
                ///////////          END Update Last Log Date Field Or not         ///////////////////////////////////////////////////////////////////////////////////////// ///////////////////////////////
                // Print to flash
                exit();
                } // close the if (isset($_COOKIE['firstnameCookie'] section
            } // close first if statement  - $_POST['post_code'] == "check_log"
            <?php
            // ************************ This is the original check user log script WITHOUT the REMEMBER ME feature, for you to reference ****************************
            session_start();
                 } else {
                      print "member_id=$id&member_name=$firstname";
                      exit();
            • 3. Re: TypeError: Error #2007: Parameter text must be non-null.
              there's no problem with that code.  you must have a cross-domain security issue.
              • 4. Re: TypeError: Error #2007: Parameter text must be non-null.
                mtataric Level 1
                Thanks! You are right! It must be something like that because it does it with every single SWF/PHP file I upload on my server. Is there a way to fix this cross-domain security issue?? PHP is enabled. It just won't work with flash files..
                • 5. Re: TypeError: Error #2007: Parameter text must be non-null.
                  you need a cross-domain security file on the server with the php file.
