5 Replies Latest reply on Jul 11, 2009 1:55 PM by kglad
    simplify with array loops?
    christoon_ca
      Hey all
      I have a test here which is for a more complex interaction, but the principle is the same. What I would like to know is how to make the code more efficient, possibly through array loops?
      Any help is appreciated
        • 1. Re: simplify with array loops?
          your chances of getting help are diminished if files need to be downloaded.
          • 2. Re: simplify with array loops?
            christoon_ca Level 1
            Oh, sorry. The premise is you click an object on the right, then click an object on the left to match. Then you click a "check" box and if the scores add up correctly you win.
            Here's the code
            stop();
            // right //
            var r1Var = 0;
            var score_r1 = 0;
            r1.onRelease = function() {
                if (r1Var == 0) {
                    r1.gotoAndStop(2);
                    r1Var = 1;
                } else if (r1Var == 1) {
                    r1.gotoAndStop(1);
                    r1Var = 0;
                } else if (r1Var == 2) {
                    r1a._x = 684;
                    r1a._y = 180;
                    r1.gotoAndStop(1);
                    r1Var = 0;
                    score_r1 = 0;
            var r2Var = 0;
            var score_r2 = 0;
            r2.onRelease = function() {
                if (r2Var == 0) {
                    r2.gotoAndStop(2);
                    r2Var = 1;
                } else if (r2Var == 1) {
                    r2.gotoAndStop(1);
                    r2Var = 0;
                } else if (r2Var == 2) {
                    r2a._x = 684;
                    r2a._y = 207;
                    r2.gotoAndStop(1);
                    r2Var = 0;
                    score_r2 = 0;
            var r3Var = 0;
            var score_r3 = 0;
            r3.onRelease = function() {
                if (r3Var == 0) {
                    r3.gotoAndStop(2);
                    r3Var = 1;
                } else if (r3Var == 1) {
                    r3.gotoAndStop(1);
                    r3Var = 0;
                } else if (r3Var == 2) {
                    r3a._x = 684;
                    r3a._y = 234;
                    r3.gotoAndStop(1);
                    r3Var = 0;
                    score_r3 = 0;
            // left //
            l1.onRelease = function() {
                if (r1Var == 1) {
                    r1a._x = this._x + 60;
                    r1a._y = this._y
                    r1Var = 2;
                    if (score_r2 == 0) {
                        score_r2 += 1
                    r2a._x = this._x + 60;
                    r2a._y = this._y
                    r2Var = 2;
                    r3a._x = this._x + 60;
                    r3a._y = this._y
                    r3Var = 2;
            l2.onRelease = function() {
                if (r1Var == 1) {
                    r1a._y = this._y
                    r1Var = 2;
                    r2a._y = this._y
                    r2Var = 2;
                    if (score_r3 == 0) {
                        score_r3 += 1
                    r3a._y = this._y
                    r3Var = 2;
            l3.onRelease = function() {
                if (r1Var == 1) {
                    if (score_r1 == 0) {
                        score_r1 += 1
                    r1a._y = this._y
                    r1Var = 2;
                    r2a._y = this._y
                    r2Var = 2;
                    r3a._y = this._y
                    r3Var = 2;
            check1.onRelease = function() {
                if (score_r1 + score_r2 + score_r3 == 3) {
                    _root.gotoAndStop(2);
                } else {
                    _root.gotoAndStop(3);
            TA.onRelease = function() {
                (_root.gotoAndStop(1));
            • 3. Re: simplify with array loops?
              try:
              var tl:MovieClip=this;
              for(var i=1;i<=3;i++){
              tl["r"+i+"Var"] = 0;
              tl["score_r"+i] = 0;
              tl["r"+i].rvar=tl["r"+i+"Var"];
              tl["r"+i].rscore = tl["score_r"+i];
              tl["r"+i].ra = tl["r"+i+"a"];
              tl["r"+i].onRelease = function() {
                  if (this.rvar == 0) {
                      this.gotoAndStop(2);
                      this.rvar = 1;
                  } else if (this.rvar == 1) {
                      this.gotoAndStop(1);
                      this.rvar = 0;
                  } else if (this.rvar == 2) {
                      this.ra._x = 684;
                      this.ra._y = 180;
                      this.rvar = 0;
                      this.rscore = 0;
              similarly for l1,l2,l3
              • 4. Re: simplify with array loops?
                ....................................................wow.
                Ok, I'll try that.
                Thank you very much
                • 5. Re: simplify with array loops?
                  you're welcome.
