4 Replies Latest reply on Jul 12, 2009 1:16 AM by Dean Utian
    Text Field filter out anything other than "0123456789" and put it back into the field
    MAC800
      First of all
      using D11
      Windows XP
      Question
      Lets say text member "Data" = "[434]"
      And I only want the text of member "Data" to have digits and no other characters. What script can you use to remove  them?
      So "[434]" would  become  "434"
      I had something like the below ... got a headache and gave up....   anyone help?
      on enterFrame
      legalcharacters = "0123456789"
      member("Data").text = legalcharacters(member("Data")
      end
      Am I way off?
        • 1. Re: Text Field filter out anything other than "0123456789" and put it back into the field
          Dean Utian Adobe Community Professional
          Hi Mac,
          You can get the value of  a string with value().
          Say you have a string  "[434]". This may be member("Data").text
          Data =  member("Data").text
          put Data
          -- "[434]"
          put value(Data)
          -- [434]
          put (value(Data))[1]
          -- 434
          Data = (value(Data))[1]
          member("Data").text  = string(Data)
          put  member("Data").text
          -- "434"
          Getting the value of a  string "[434]" returns a list. That's why you need the extra step.
          If the text was something  like "a123" then the value of this string would be VOID as  "a" cannot be converted to a value. However, you can use 'the  itemDelimiter'. This lets you set a special character (like "a") to  be used to separate items.
          the itemDelimiter =  "a"
          Data =   "a123"
          put Data.item[2]
          -- "123"
          put value(Data.item[2])
          -- 123
          Dean
          Director Lecturer /  Consultant / Director Enthusiast
          http://www.deansdirectortutorials.com/
          http://www.multimediacreative.com.au
          • 2. Re: Text Field filter out anything other than "0123456789" and put it back into the field
            MAC800 Level 1
            Re:
            I get most of the above.  But why is the [1] needed in Data = (value(Data))[1] ?
            Conclusion ----  So if I understand correctly
            Then all I need is the following?
            on enterFrame
            end
            • 3. Re: Text Field filter out anything other than "0123456789" and put it back into the field
              Sean_Wilson Adobe Community Professional
              Dean gave you a possibility, but his solution will only work to remove [ and ] characters, and then only if they are the first and last chars in the string of text.
              Can you be more specific about where your data is coming from? If it is user entered, then do you also need to filter alphabet characters out? You could use a JavaScript member and its regular expression object for a more general approach:
              -- in my message window:
              s = "1234abcg465(&*^"
              put s
              -- "1234abcg465(&*^"
              put jsReplace(s, "\D", "")
              -- "1234465"
              Here's the jsReplace() function - it should go into a #movie script whose scriptSyntax is set to #JavaScript:
              function jsReplace(inStr, strFind, strReplace){
                // error check input
                if(typeof(inStr)      != "string") { return inStr; }
                if(typeof(strFind)    != "string") { return inStr; }
                if(typeof(strReplace) != "string") { return inStr; }
                // search-and-replace
                re = new RegExp(strFind, "g");
                return inStr.replace(re, strReplace);
              • 4. Re: Text Field filter out anything other than "0123456789" and put it back into the field
                If we look at the text string - "[434]" - we see square brackets at the start and end. So, if we convert the string to a value, we get - [434] - which is a list. The [1] retrieves the first item in the list (which is the only item in the list). For more info on lists, look at:
                http://www.deansdirectortutorials.com/Lingo/lists.htm
                dataString = "[434]"
                dataList = value(dataString)
                dataInteger = dataList[1]
                So, the above grabs the value 424 by converting the text into  a list, then grabbing item 1 in this list.
                My second suggestion was to use - the itemDelimiter =  "a"
                dataString "a434"
                dataPartialString = dataString.item[2]
                The above assumes you have a character like 'a' that acts as the separater for numerical characters. Item 1 would be before the 'a' which wouuld be nothing (""). Item 2 is the characters after the first 'a' (up until the next 'a' if one exists).
                The above would only work if you know what character is going to be at the start the numerical sequence. If you need something more flexible, then Sean's jsReplace approach would be the best way to go.
                Dean
