Just installed the CF Builder Beta and as soon I try and run it I get the following error:
A Java Runtime Environment (JRE) or Java Development Kit (JDK) must be available in order to run CFBuilder. No Java virtual machine was found after searching the following locations:
C:\Program Files\Adobe\Adobe ColdFusion Builder\jre\bin\javaw.exe
javaw.exe in current PATH
I have JRE6u14 installed and I have reinstalled it to make sure but still nothing. The path in the error message doesn't exist, there is no "jre" directory in the CFBuilder directory.
Not a very good start!!! Any ideas?
Andrew.
CFBuilder require a 32 bit jre to be available.
So you if you already have a jre installed ,can you check if the jre path is available in the system path variable .
On which OS are you trying to install CFBuilder?
Evelin
Evelin
Ok, that was the problem, had to add C:\Program Files\Java\jre6\bin\ to the system path variable. For anyone else who has this problem, do the following:
1) Locate the path to the Java installation, probably something like C:\Program Files\Java\jre6\bin\.
2) Go to "My Computer" and right click and select "Properties" from the context menu.
3) In the "System Properties" dialog, select the "Advanced" tab.
4) From the "Advanced" tab, click the "Environment Variables" button.
5) The "Environment Variables" dialog box will appear and has two sections, "User variables" (top section) and "System variables" (bottom section). In the "System Variables" section scroll down the variables until you find "Path". Click it to select it and then click the "Edit" button (below).
6) The "Edit System Variable" dialog will appear for the "Path" varialbe. Add your path to the end of the value in the "Variable value" field, adding a semi-colon (;) before enter your path to delimit it from the previous entry.
7) Click Ok, Ok and Ok to close all the dialog boxes and then run CFBuilder.
Kind regards,
Andrew.
thank you, andrew!!!!
My version of Eclipse all of sudden started to do this and your solution fixed my issue. I don't work with ColdFusion Builder. I work with Flex Builder, but I think my problem was not related to an Adobe product but rather a general Eclipse issue. Sometimes I hate open source projects like Eclipse.
Again thanks for reporting the detailed instructions on how you resolved your issue.
