0 Replies Latest reply on Jul 13, 2009 6:07 AM by ma.tze
    datagrid with a datadriven combox
    ma.tze
      I would like to implement a datagrid with a datadriven combox.
      The database should store "only" values, but should show a different labeltext in the grid.
      When the users load this Grid the stores values should be uses to set the comboboxes.
      That sounds easy but I haven't found a easy way to implement that!
      1.) I need to overrite the "save column" function of the generated code from FB4b1, so that the shown labeltext is not saved, but its db-values.
      How can I do this?
      2.) I need to build the combox in the datagrid, but there is nnothing like"combox.value="myValID" ( that would be all in vb.net)
      Do I have to loop manually over the selectedIndex until I found my savedValue?
      Like
      http://www.boyzoid.com/blog/index.cfm/2006/11/22/Flex-Custom-Components-and-Custom-Methods
      Is there an easier way to do this?
      Thanks for any pointers!
      Martin Zach
