2 Replies Latest reply on Jul 13, 2009 12:41 PM by lee704
    Enable button based on ComboBox Selection
    lee704
      Ist there a way to enable or disable a button based on the value selected in a ComboBox?  If so, what is the syntax?  Attached is what I have:
      <?xml version="1.0"?>
      <!-- Simple example to demonstrate the ComboBox control. -->
      <mx:Application
      xmlns:mx="http://www.adobe.com/2006/mxml"
      <mx:Script>
      <![CDATA[
      import
      mx.collections.ArrayCollection;
      Bindable
      public var cards:ArrayCollection = new
      ArrayCollection(
      [ {label:
      "Visa"
      , data:1},
      {label:
      "MasterCard"
      , data:2},
      {label:
      "American Express"
      , data:3} ]);
      private function closeHandler(event:Event):void
      myLabel.text =
      "You selected: "
      + ComboBox(event.target).selectedItem.label;
      myData.text =
      "Data: "
      + ComboBox(event.target).selectedItem.data;
      </mx:Script>
      <mx:Panel title="ComboBox Control Example" height="75%" width="75%" layout="horizontal">
      <mx:ComboBox dataProvider="{cards}" close="closeHandler(event);" id="cardsComboBox"/>
      <mx:VBox>
      <mx:Text text="Select a type of credit card."/>
      <mx:Label id="myLabel" text="You selected:"/>
      <mx:Label id="myData" text="Data:"/>
      <mx:Button label="Button" id="cardsButton" enabled="{cardsComboBox.selectedIndex.valueOf()}"/>
      </mx:VBox>
      </mx:Panel>
      </mx:Application>
      I need the "enabled" property of the "cardsButton" object to vary based on what the users selects in the "cardsComboBox" object.  If the user selects an item with a selectedIndox > 0, I want the button to be enabled.
      Any suggestion how to correct my code to accomplish this?
        • 1. Re: Enable button based on ComboBox Selection
          tcflex
          For the combo box, implement the changeHandler for change event.
          <mx:ComboBox dataProvider="{cards}" close="closeHandler(event);" id="cardsComboBox" change="changeHandler(event)"/>
          private function changeHAndler(evnt:ListEvent):void {
          if(event.currentTaraget.selectedIndex > 0)
            cardsButton.enabled = true;
          else
            cardsButton.enabled = false;
          tc.
          • 2. Re: Enable button based on ComboBox Selection
            lee704 Level 1
            Excellant!  Thank you.  The completed code is listed below:
                        private function changeHandler(event:Event):void
                            if (event.currentTarget.selectedIndex > 0)
                                cardsButton.enabled=true;
                            else
                                cardsButton.enabled=false;
                    <mx:ComboBox id="cardsComboBox"
            As a follow-up, I need to add one more clause to my conditions.  I need to also check to see if CheckBox "ckCheckBox" is selected.  Only if this condition, plus the previous condition must be met before the cardsButton is enabled.  Can I just add a clause to the first condition like:
            if (event.currentTarget.selectedIndex > 0) and ckCheckBox.selected = TRUE
            if so, what would be the syntax?
            Thanks again!
