10 Replies Latest reply on Jul 15, 2009 8:17 AM by Deeps45
    DisplayObject must be a child of the caller.
    Deeps45 Level 1
      I am trying to remove the existing childs  (combobox and pods are the content in the page) using
      viewStack.selectedChild.removeAllChildren();
      in a tab click from the Viewstacks canvas.
      then I am trying to add new child.
      it gives this error.
      The supplied DisplayObject must be a child of the caller.
      at flash.display::DisplayObjectContainer/getChildIndex()
      at mx.core::Container/setChildIndex()[C:\autobuild\3.2.0\frameworks\projects\framework\src\m x\core\Container.as:2449]
      Please help me to fix this
        • 1. Re: DisplayObject must be a child of the caller.
          Flex harUI Adobe Employee
          Show the full stack trace and the code you are using to add the child
          Alex Harui
          Flex SDK Developer
          Adobe Systems Inc.
          Blog: http://blogs.adobe.com/aharui
          • 2. Re: DisplayObject must be a child of the caller.
            Deeps45 Level 1
            private function onApplicationComplete():
            void
            var arrView:Array =new
            Array();
            arrView=viewStack.getChildren();
            viewLength=arrView.length;
            // Load pods.xml, which contains the pod layout.
            var httpService:HTTPService = new
            HTTPService();
            httpService.url =
            "data/pods.xml"
            httpService.resultFormat =
            "e4x"
            httpService.addEventListener(FaultEvent.FAULT, onFaultHttpService);
            httpService.addEventListener(ResultEvent.RESULT, onResultHttpService);
            httpService.send();
            private function onFaultHttpService(e:FaultEvent):
            void
            Alert.show(
            "Unable to load data/pods.xml."
            public var viewXMLList:XMLList =new
            XMLList();
            private function onResultHttpService(e:ResultEvent):
            void
            viewXMLList = e.result.view;
            var podcontentbase:PodContentBase=new
            PodContentBase;
            var containerWindowManagerHash:Object = new
            Object();
            var
            len:Number = viewXMLList.length();
            if
            (podLayoutManagers.length!=0)
            podLayoutManagers.splice(0,podLayoutManagers.length);
            for (var i:Number = 0; i < len; i++)
            // Loop through the view nodes.
            // Create a canvas for each view node.
            var canvas:Canvas = new
            Canvas();
            // PodLayoutManager handles resize and should prevent the need for
            // scroll bars so turn them off so they aren't visible during resizes.
            canvas.horizontalScrollPolicy =
            "off"
            canvas.verticalScrollPolicy =
            "off"
            canvas.label = viewXMLList[i].@label;
            canvas.percentWidth = 100;
            canvas.percentHeight = 100;
            viewStack.addChild(canvas);
            traceDL(viewStack);
            // Create a manager for each view.
            var manager:PodLayoutManager = new
            PodLayoutManager();
            manager.container = canvas;
            manager.id = viewXMLList[i].@id;
            manager.addEventListener(LayoutChangeEvent.UPDATE, StateManager.setPodLayout);
            // Store the pod xml data. Used when view is first made visible.
            podDataDictionary[manager] = viewXMLList[i].pod;
            //podcontentbase.podDataDictionarycopy[manager] = viewXMLList[i].pod;
            podLayoutManagers.push(manager);
            onchange();
            private function onchange():
            void
            tabBar.dataProvider=viewStack;
            var
            index:Number = StateManager.getViewIndex();
            // Make sure the index is not out of range.
            // This can happen if a tab view was saved but then tabs were subsequently removed from the XML.
            index = Math.min(tabBar.numChildren - 1, index);
            onItemClickTabBar(
            new ItemClickEvent(ItemClickEvent.ITEM_CLICK, false, false, null
            , index));
            tabBar.selectedIndex = index;
            private var
            indextab:Number;
            private function onItemClickTabBar(e:ItemClickEvent):
            void
            indextab = e.index;
            StateManager.setViewIndex(indextab);
            // Save the view index.
            viewStack.selectedIndex = indextab;
            if( this
            .contains( viewStack.selectedChild) )
            traceDL(
            this
            • 3. Re: DisplayObject must be a child of the caller.
              I didn't see the full stacktrace.  Usually that error shows up in a dialog with many more lines in it
              Alex Harui
              Flex SDK Developer
              Adobe Systems Inc.
              • 4. Re: DisplayObject must be a child of the caller.
                Deeps45 Level 1
                This is the exact error im getting
                ArgumentError: Error #2025: The supplied DisplayObject must be a child of the caller.
                at flash.display::DisplayObjectContainer/setChildIndex()
                at mx.core::Container/setChildIndex()[C:\autobuild\3.2.0\frameworks\projects\framework\src\m x\core\Container.as:2442]
                at com.esria.samples.dashboard.managers::PodLayoutManager/updateLayout()[C:\Documents and Settings\My Documents\Flex Builder 3\Dashboard\src\com\esria\samples\dashboard\managers\PodLayoutManager.as:471]
                at Dashboard/onCreationCompletePod()[C:\Documents and Settings\My Documents\Flex Builder 3\Dashboard\src\Dashboard.mxml:382]
                at flash.events::EventDispatcher/dispatchEventFunction()
                at flash.events::EventDispatcher/dispatchEvent()
                at mx.core::UIComponent/dispatchEvent()[C:\autobuild\3.2.0\frameworks\projects\framework\src \mx\core\UIComponent.as:9298]
                at mx.managers::LayoutManager/doPhasedInstantiation()[C:\autobuild\3.2.0\frameworks\projects \framework\src\mx\managers\LayoutManager.as:719]
                at Function/http://adobe.com/AS3/2006/builtin::apply()
                at mx.core::UIComponent/callLaterDispatcher2()[C:\autobuild\3.2.0\frameworks\projects\framew ork\src\mx\core\UIComponent.as:8628]
                at mx.core::UIComponent/callLaterDispatcher()[C:\autobuild\3.2.0\frameworks\projects\framewo rk\src\mx\core\UIComponent.as:8568]
                • 5. Re: DisplayObject must be a child of the caller.
                  Deeps45 Level 1
                  Please help me in fixing this.. Thanks in advance
                  • 6. Re: DisplayObject must be a child of the caller.
                    You will have to seek help from the PodLayoutManager folks.  It is their code that appears to be calling setChildIndex incorrectly, although it is possible that our oncCreationCOmpletePod() method is setting them up to fail.
                    Alex Harui
                    Flex SDK Developer
                    Adobe Systems Inc.
                    • 7. Re: DisplayObject must be a child of the caller.
                      *Prashant Shelke* Level 4
                      have you tried using
                      if( viewStack.getChildAt(viewStack.selectedIndex) ! =null && viewStack.getChildAt(viewStack.selectedIndex.children.length > 0)
                              viewStack.getChildAt(viewStack.selectedIndex.removeAllChildre();
                      • 8. Re: DisplayObject must be a child of the caller.
                        Deeps45 Level 1
                        I tried someother way. The issue was fixed now.Thank you.
                        • 9. Re: DisplayObject must be a child of the caller.
                          Deeps45 Level 1
                          My application is working fine, but sometimes i get the following runtime error.
                          When i debugged it i find that the error is because of width parameter while creating rectangle.
                          width here is refering to UI.component width. the width value is coming as NAN.
                          rc:Rectangle = new Rectangle(w, w, width - 2 * w, height - 2 * w);
                          ArgumentError: Error #2004: One of the parameters is invalid.
                          at flash.display::Graphics/drawRect()
                          at qs.charts.renderers::RollOverBoxItemRenderer/updateDisplayList()[C:\Documents and Settings\dganeshan\My Documents\Flex Builder 3\RecoveryDashboard\src\qs\charts\renderers\RollOverBoxItemRenderer.as:138]
                          at mx.core::UIComponent/validateDisplayList()[C:\autobuild\3.2.0\frameworks\projec ts\framework\src\mx\core\UIComponent.as:6351]
                          at mx.managers::LayoutManager/validateDisplayList()[C:\autobuild\3.2.0\frameworks\ projects\framework\src\mx\managers\LayoutManager.as:622]
                          at mx.managers::LayoutManager/doPhasedInstantiation()[C:\autobuild\3.2.0\framework s\projects\framework\src\mx\managers\LayoutManager.as:695]
                          at mx.core::UIComponent/callLaterDispatcher2()[C:\autobuild\3.2.0\frameworks\proje cts\framework\src\mx\core\UIComponent.as:8628]
                          at mx.core::UIComponent/callLaterDispatcher()[C:\autobuild\3.2.0\frameworks\projec ts\framework\src\mx\core\UIComponent.as:8568]
                          Please let me know if you have any idea about this problem.. Thanks in advance
                          var
                          • 10. Re: DisplayObject must be a child of the caller.
                            Deeps45 Level 1
                            var
