5 Replies Latest reply on Jul 14, 2009 3:40 PM by trmnshwrx
    Flex not understanding ArrayCollection passed from PHP
    trmnshwrx Level 1
      First, I'm using Flex Builder 3, Wamp with PHP 5.2.9-2 and MySQL 5.1.33.  I'm also using the Zend Framework to get data from MySQL.
      I have Flex using an HTTPService to send a request; the server then executes some PHP that reads a MySQL database, writes each row into an array, all the rows into an array.  Though I have changed the actual data, here's what my a call on my MySQL database returns:
      SELECT  *
      FROM  `table1`
      LIMIT 0 , 30
      1     VideoDescription     filename.flv
      2     otherDescription      filename2.flv
      3     thirdDescription       filename3.flv
      The names of the columns are "id", "title", and "source", respectively.
      The arrays in php seem to work fine, because in PHP,
      print($result[1]['title']);
      will give us "otherDescription", and we can see that easily in Flex.
      The problem is that I don't want "otherDescription"; I want the whole table passed to Flex as an array collection.
      I am able to pass the array from php, and then it is just an "Array" that I can't do anything with.  No matter what I trace from it, it always says "Array", or it simply does not work...why is this?  Why can't I get anything out of it?  The only useful thing I can pass from PHP to Flex is a String, and that's kind of awkward for what I'm doing.
      Here's my PHP code:
      <?php
           require('Zend/Db/Adapter/Pdo/Mysql.php');
           $arr = array('host' => '127.0.0.1','username' => 'root','password' => '','dbname' => 'videolist');
           $db = new Zend_Db_Adapter_Pdo_Mysql($arr);
           $db->getConnection();
           $sql = 'SELECT * FROM `table1` LIMIT 0 , 30';
           $result = $db->fetchAll($sql, 2);
           $resultArray = array();
           foreach($result as $resultItem){
                foreach($resultItem as $itemFragment){
                     $resultArrayFragment[] = $resultItem;
                $resultArray[] = $resultArrayFragment;
           echo $result;  // or, to illustrate the way the array collection works, we can put "$result[1]['title'];", in which case, Flex will show "otherDescription"
                                   //  for the traces below
      Here's my relevant ActionScript:
      private function onResult():void{     //this is fired as we get a result after calling the HTTPService send()
           var result = userRequest.lastResult;
           trace("trace 1 = " + String(userRequest.lastResult));     // produces: "Array"
           trace("trace 2 = " + result[1]["title"]);                           // produces: "Array"
           trace("trace 3 = " + result[1]["title"][0][0][0][0]);            // STILL just produces: "Array"
           var someDataProvider:ArrayCollection = new ArrayCollection(userRequest.lastResult.valueOf());
          trace("trace 4 = " + result[0]);                                     // produces: "RangeError: Index '1' specified is out of bounds..."
