0 Replies Latest reply on Jul 13, 2009 4:23 PM by Chet Haase
    [svn:fx-trunk] 8535: Fixed some transform effects bugs plus a GraphicElement.localToGlobal() bug with the shared display object.
    Chet Haase Level 3
      Revision: 8535
      Author:   chaase@adobe.com
      Date:     2009-07-13 16:23:47 -0700 (Mon, 13 Jul 2009)
      Log Message:
      QE Notes: 8 failures in transform effects tests, 1 in Resize test, require changes to the test (new, correct behavior causes a change in the relevantStyles and affectedProperties return values)
      Doc Notes: None
      Bugs: sdk-21875, sdk-21465, sdk-21804, sdk-22165, sdk-21933
      Reviewer: Jason, Glenn (for 21933)
      Tests: checkintests, Mustella (spark/effects, mx/effects), Catalyst transition test
      Ticket Links:
          http://bugs.adobe.com/jira/browse/sdk-21875
          http://bugs.adobe.com/jira/browse/sdk-21465
          http://bugs.adobe.com/jira/browse/sdk-21804
          http://bugs.adobe.com/jira/browse/sdk-22165
          http://bugs.adobe.com/jira/browse/sdk-21933
      Modified Paths:
          flex/sdk/trunk/frameworks/projects/framework/src/mx/effects/Effect.as
          flex/sdk/trunk/frameworks/projects/spark/src/spark/effects/AnimateTransform.as
          flex/sdk/trunk/frameworks/projects/spark/src/spark/effects/Move.as
          flex/sdk/trunk/frameworks/projects/spark/src/spark/effects/Move3D.as
          flex/sdk/trunk/frameworks/projects/spark/src/spark/effects/Resize.as
          flex/sdk/trunk/frameworks/projects/spark/src/spark/effects/Rotate.as
          flex/sdk/trunk/frameworks/projects/spark/src/spark/effects/Rotate3D.as
          flex/sdk/trunk/frameworks/projects/spark/src/spark/effects/Scale.as
          flex/sdk/trunk/frameworks/projects/spark/src/spark/effects/Scale3D.as
          flex/sdk/trunk/frameworks/projects/spark/src/spark/effects/animation/Animation.as
          flex/sdk/trunk/frameworks/projects/spark/src/spark/effects/supportClasses/AnimateTransfor mInstance.as
          flex/sdk/trunk/frameworks/projects/spark/src/spark/primitives/supportClasses/GraphicEleme nt.as
