3 Replies Latest reply on Jul 16, 2009 6:38 AM by jbenson@oper8
    TypeError: Error #2007: Parameter listener must be non-null.
    slapyo
      I've searched the forums and all over the web and have not found an answer.  I don't know why I get this error.  It's extremely simple at the moment, starting the app.  It was working when I had all the functions not in an object.  Any help would be greately appreciated.
          at flash.events::EventDispatcher/removeEventListener()
      $(document).ready(function() {
          MyApp.init();
      var MyApp = {
          prefsFile: '',
          prefsXML: '',
          stream: '',
          init: function() {
              window.nativeWindow.addEventListener(air.Event.CLOSING, this.windowClosingHandler);
              this.prefsFile = air.File.applicationStorageDirectory;
              this.prefsFile = this.prefsFile.resolvePath("preferences.xml");
              this.readXML();
          readXML: function() {
              this.stream = new air.FileStream();
              if (this.prefsFile.exists) {
                  this.stream.open(this.prefsFile, air.FileMode.READ);
                  this.processXMLData();
              } else {
                  this.saveData();
          processXMLData: function() {
              this.prefsXML = this.stream.readUTFBytes(this.stream.bytesAvailable);
              this.stream.close();
              var domParser = new DOMParser();
              this.prefsXML = domParser.parseFromString(this.prefsXML, "text/xml");
              var windowState = this.prefsXML.getElementsByTagName("windowState")[0];
              window.moveTo(windowState.getAttribute("x"), windowState.getAttribute("y"));
          saveData: function() {
              this.createXMLData();
              this.writeXMLData();
          createXMLData: function() {
              var cr = air.File.lineEnding;
              this.prefsXML =   "<?xml version='1.0' encoding='utf-8'?>" + cr
                  + "<preferences>" + cr
                  + "    <windowState" + cr
                  + "        x = '" + window.screenLeft.toString() + "'" + cr
                  + "        y = '" + window.screenTop.toString() + "'" + "/>" + cr
                  + "    <saveDate>" + new Date().toString() + "</saveDate>" + cr
                  + "</preferences>";
          writeXMLData: function() {
              this.stream.open(this.prefsFile, air.FileMode.WRITE);
              this.stream.writeUTFBytes(this.prefsXML);
          windowClosingHandler: function(e) {
              e.preventDefault();
              window.nativeWindow.removeEventListener(air.Event.CLOSING, this.windowClosingHandler);
              this.saveData();
              air.NativeApplication.nativeApplication.exit();
        • 1. Re: TypeError: Error #2007: Parameter listener must be non-null.
          jbenson@oper8 Level 2
          within your function "MyApp.windowClosingHandler" you call removeEventListener like so:
          The issue is that your function (windowClosingHandler) is being called by the event air.Event.CLOSING and windowClosingHandler is not a member of it.  (IE this in that context is not the function/namespace "MyApp" but rather the event)
          So change your code from:
          To
          window.nativeWindow.removeEventListener(air.Event.CLOSING, MyApp.windowClosingHandler);
          and you will no longer receive that message.
          hope that helps!
          • 2. Re: TypeError: Error #2007: Parameter listener must be non-null.
            slapyo Level 1
            Actually, that didn't work.  I forgot to mention that I tried that.  This is the solution that I found.
            Function.prototype.bind = function(context) {
                var fn = this;
                return function(){
                    if(arguments.length !== 0) {
                        return fn.apply(context, arguments);
                    } else {
                        return fn.call(context);
            Then inside in the init function and windowClosingHandler I used this.
                init: function() {
                    window.nativeWindow.addEventListener(air.Event.CLOSING, Stoker.windowClosingHandler.bind(Stoker));
                    this.readXML();
                    e.preventDefault();
                    window.nativeWindow.removeEventListener(air.Event.CLOSING, Stoker.windowClosingHandler.bind(Stoker));
                    this.saveData();
            • 3. Re: TypeError: Error #2007: Parameter listener must be non-null.
              That's interesting.  When I tested your code the only error I raised on application exit after changing to MyApp was an error on the method saveData.
              Regardless glad you got it working!
