0 Replies Latest reply on Jul 13, 2009 9:40 PM by Peter Farland
    [svn:fx-trunk] 8537: Integrating latest fxgutils fixes from Sujata and Min for the following issues :
    Peter Farland Level 3
      Revision: 8537
      Author:   pfarland@adobe.com
      Date:     2009-07-13 21:40:40 -0700 (Mon, 13 Jul 2009)
      Log Message:
      Integrating latest fxgutils fixes from Sujata and Min for the following issues:
      - MXMLC compiler doesn't recognize scientific notation for values in path data
      - radial gradient for strokes doesn't get modified by a matrix transformation)
      - output from fxgutils for stroke/radial_gradient_stroke/radial_gradient_stroke_path_focal_point.fxg does not match output from mxmlc
      - output from fxgutils for stroke/radial_gradient_stroke/ radial_gradient_stroke_path_spread.fxg does not match output from mxmlc
      - All color transform files don't match output from mxmlc.
      - Allow FXGUtils to process FXG 2.0 files and log a warning instead of throwing an exception.
      Also exposing the unicode parser logic in FontManager to assist in font utility creation.
      QE: Yes
      Doc: No
      Checkintests: Pass
      mxunit fonts: Pass
      Modified Paths:
          flex/sdk/trunk/lib/flex-fontkit.jar
          flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/fxg/FXGCompiler.java
          flex/sdk/trunk/modules/fxgutils/src/java/com/adobe/fxg/swf/FXG2SWFTranscoder.java
          flex/sdk/trunk/modules/fxgutils/src/java/com/adobe/internal/fxg/dom/AbstractFXGNode.java
          flex/sdk/trunk/modules/fxgutils/src/java/com/adobe/internal/fxg/dom/BitmapGraphicNode.jav a
          flex/sdk/trunk/modules/fxgutils/src/java/com/adobe/internal/fxg/sax/FXGSAXScanner.java
          flex/sdk/trunk/modules/fxgutils/src/java/com/adobe/internal/fxg/swf/ShapeHelper.java
          flex/sdk/trunk/modules/fxgutils/src/java/com/adobe/internal/fxg/swf/TypeHelper.java
          flex/sdk/trunk/modules/swfutils/src/java/flash/fonts/FontManager.java
      Added Paths:
          flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/fxg/FlexLoggerAdapter.java
          flex/sdk/trunk/modules/fxgutils/src/java/com/adobe/fxg/util/FXGLog.java
