In the Coldfusion8 Doc you can read:
Adobe recommends that you use BOM characters in your files.
(http://livedocs.adobe.com/coldfusion/8/htmldocs/help.html?content=i18n_10.html)
How can we change the encoding from utf-8 without BOM to utf-8 with BOM? I think it is an internal eclipse problem.
Does anyone know a goog solution for this problem?
I try the new Beta2 and we have the same problem!
Does anyone know a good solution for this problem?
The docs are talking nonsense: there's not need to specify a BOM. Just set your default encoding to UTF-8.
If your CF templates have any non-ASCII characters in them, then tell the compiler to expect UTF-8 data using the <cfprocessingdirective> tag.
Adam
Hello Adam
I think this is not a good solution. All of our current files uses UTF-8 BOM we don't want do change every file.
How can we change the default compiler behavor to recognize all files as UTF-8?
How can we change the default processingdirective?
Every good texteditor can add BOM to UTF-8 Files.
push
I don't see what your problem is here.
If you tell CFB to create new files as UTF-8, it will. It does not put a BOM in the file, but the BOM is not necessary for the file to be recognised as UTF-8. Equally, there is no problem if your files do have a BOM.
What actual problem are you having here? Actual problem, not theoretical problem. Why do you need there to be a BOM in the file?
Adam
Also, have you raised an enhancement request for this (but you better provide a thorough rationale for it!):http://cfbugs.adobe.com/bugreport/flexbugui/cfbugtracker/main.html
Adam
I have the same problem !!!
In my case, we need to output chinese/japanese pages.
The CFB (ColdFusion Builder) do not write BOM to .cfm files, so it will display random code when we save>close>reopen it.
and also, CF server 8 do not display correct characters in web page.
But, if we reopen it and save it to UTF8 by notepad. (or by Dreamweaver with BOM checked)
it will display chinese/japanese normally.....
we don't want to re-save all files by notepad or other applications.
and for edit these files by CFB, I think the BOM function is necessary.
actually, the problem CFB create files as UTF-8 without BOM is we have no idea to edit a cfml include other language like chinese or japanese !!
how can we slove this problem?
(I know the BOM is not necessary for UTF-8. but if I want to edit a cfm with chinese characters inside, it seems to be necessary.)
(Sorry if I misspelled something, my native language is chinese.)
the unicode spec says the BOM is optional for UTF-8 (which if you think about
it's not needed, there's only the 1 byte order for UTF-8). eclipse, which cf
builder (CFB), cfeclipse (CFE), et al is based on, doesn't write out a BOM.
i use thai, japanese, arabic, etc. in cf files edited w/CFB, CFE & even with
notepad (don't ask). all work fine.
are you sure your files are utf-8 encoded in the 1st place? can you zip up &
attach a simple example of one that's causing you problems?
Thanks Paul,
it so strange...
since you made a response to me, I tried to install CFB on my home pc.
and it's just incredible work fine.. = ="
I think the problem is on my work pc...........
I will try it tomorrow,
and thanks for your enthusiastic help.
