1 Reply Latest reply on Nov 8, 2009 4:59 PM by matthew.zimmer
    Best installation configuration with ColdFusion Builder?
    ericbelair Level 1
      I want to install both the new ColdFusion Builder and Flash Builder 4, and I'm wondering what people think is the best installation configuration. Here are what I see as the options:
      1. ColdFusion Builder standalone + Flash Builder 4 standalone
      2. ColdFusion Builder standalone + Flash Builder 4 plug-in to the same installation
      3. ColdFusion Builder plug-in to Eclipse + Flash Builder 4 standalone
      4. ColdFusion Builder plug-in to Eclipse + Flash Builder 4 plug-in to the same installation
      For the past two years I have been working with the following configuration:
      • Adobe CS3 (Dreamweaver/Fireworks) standalone + Flex Builder 3 standalone + CFEclipse plug-in to Eclipse
      I switch between using Dreamweaver CS3 and CFEclipse all the time based on what fits my need at the specific time (i.e. I find it much easier to edit CSS in Dreamweaver).
      I tried the Flex Builder 3 Eclipse plug-in a while back, because I wanted to use it with my CFEclipse installation, but I found teh FB3 standalone MUCH easier to use, so I am apprehensive about trying the FB4 plug-in.
      I would love to have everything in one place, but more important is ease of use - even if that means having two programs (i.e. CFBuilder and FB4) open at the same time, since that is what I have been doing for sometime now.
      Curious what people have tried and had success with.
      Thanks.
        • 1. Re: Best installation configuration with ColdFusion Builder?
          matthew.zimmer Level 1
          I like having my IDEs separate from one another for many reasons but here is my two primary reasons:
          1. Debugging
              - It is a lot easier to have the ColdFusion and Flex Builder Debuggers running side-by-side in their own IDEs so that I can easily step through them individually.
          2. Performance
              - Each instance has its own allocated memory space and can be configured inidividually via the *.ini files.
          My $0.02 worth.
