7 Replies Latest reply on Jul 14, 2009 3:04 PM by Gail Chambers
    IsoTransform Download: Now What?
    Gail Chambers
      Just downloaded a small '.aia' to create isometric renderings but what do I do with the file sitting on my desktop? Where do I put it in order to use it in Illustrator?
        • 1. Re: IsoTransform Download: Now What?
          Mario Arizmendi Level 4
          That is an action, it could be where ever you want, but the logical alocation is
          Aplications/IllustratorCs3/Presets/Actions
          Then go to the windows menu and select actions/load...
          • 2. Re: IsoTransform Download: Now What?
            Gail Chambers Level 1
            Thanks for answering but...I'm using CS4 (I also have CS3). I went to
            Finder>Applications>illustrator CS4>Presets>.en_US>Actions and found
            Default_Action.aia file and clicking on that only brought up a text
            import options box. When I clicked on that the IsoTransform file
            opened as text. Is it there? Usuable? I'm in an endless loop here!
            Nothing about loading. Should I drag and drop into the Preset folder?
            Am I missing something else?
            • 3. Re: IsoTransform Download: Now What?
              Larry G. Schneider Adobe Community Professional & MVP
              Put the new .aia file in the folder Presets>Actions and then from the flyout menu of the Actions Panel, click on Load Actions. It should open that folder and then you click on the .aia file for it to be loaded. Notice how the picture that Mario showed you has two "layers" (Default Actions and Visipak 2006), both with triangles to click and expand.
              • 4. Re: IsoTransform Download: Now What?
                No matter, put the .aia file on the presets/actions CS4 folder and STOP, DONT DO ANITHING ELSE HERE...!
                Ok, an action is claming to do something to an OBJECT, , so you must first select an object in your AI file, then go to WINDOW/ACTIONS/Load actions and select that action, and click on the play button. ( Not always an action needs an objetc selected..but must of the times)
                In my example the action is called ¨Multiplo Vasos¨ I have this selected and then click on the play button...
                It would be helpful if we know exactly what is the name of the action, I mean, what it is supposed to do, may be you can attach the file to your post.
                • 5. Re: IsoTransform Download: Now What?
                  When I go to Applications>Illustrator CS4>Presets it shows a folder
                  titled en_US. Inside is an Actions folder with a Default file. I've
                  dropped the IsoTransform file into that folder but I haven't found
                  anything that shows 'Load'. Am I blind?
                  • 6. Re: IsoTransform Download: Now What?
                    Finally! The trick was finding the fly-out menunot the drop-down
                    of Actions while in Illustrator, NOT the finder! Sheer accident that
                    I hit the fly-out icon while trying to minimize the window. What a
                    production! Now let's hope the little file actually works...
                    Thanks for your help. Amazing how many nooks and crannies there are
                    in these programs.
                    • 7. Re: IsoTransform Download: Now What?
                      in these programs. And such tiny icons...
